Hey guys,
I'm fairly new to Arduino and need some help.
I followed this tutorial and eventually got my project accomplished with some tweaks on my Uno.
However since what I'm trying to accomplish is fairly simple I wanted to try porting it over to Attiny85 and free up my Uno again.
I was able to use my Uno has a ISP and flash an ATtiny85 and was able to get a test program to work (the blink example). So with that newfound confidence I moved onto trying to figure out how to accomplish getting the Tiny to run this code:
#include <SoftwareSerial.h>
SoftwareSerial RFID(2, 3); // RX and TX
int i;
RFID.begin(9600); // start serial to RFID reader
Serial.begin(9600); // start serial to PC
if (RFID.available() > 0)
i = RFID.read();
Serial.print(i, DEC);
Serial.print(" ");
This resulted in this "Serial' was not declared in this scope" and the like:
Arduino: 1.6.5 (Mac OS X), Board: "ATtiny, ATtiny85, 8 MHz (internal)"
The sketch name had to be modified. Sketch names can only consist
of ASCII characters and numbers (but cannot start with a number).
They should also be less than 64 characters long.
Build options changed, rebuilding all
RFID_Key_Reading.ino: In function 'void setup()':
RFID_Key_Reading:9: error: 'Serial' was not declared in this scope
RFID_Key_Reading.ino: In function 'void loop()':
RFID_Key_Reading:17: error: 'Serial' was not declared in this scope
enabled in File > Preferences.
Doing some googling this seems to occur because the library for my Tiny is missing the serial command.
I had downloaded the library from here:
https://github.com/damellis/attiny/archive/702aa287455f7e052cf94fd4949398fec0ef21b8.zip
And installed it via this tutorial:
I also "burn the bootloader" so that it runs at 8 MHz just like the tutorial said for the serial command to work, but alas nada.
So I'm lost.
Some seem to say the Tiny85 can run serial, some say no. I'm posting here in the hopes that maybe someone could give me a hand and get this figured out.
The end goal is to run this bit of code on my Tiny85:
int data1 = 0;
int ok = -1;
int yes = 13;
int no = 12;
// use first sketch in http://wp.me/p3LK05-3Gk to get your tag numbers
int tag1[14] = {2,48,54,48,48,50,70,52,49,48,50,54,65,3};
int tag2[14] = {2,52,48,48,48,56,54,67,54,54,66,54,66,3};
int newtag[14] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // used for read comparisons
pinMode(yes, OUTPUT); // for status LEDs
pinMode(no, OUTPUT);
boolean comparetag(int aa[14], int bb[14])
boolean ff = false;
int fg = 0;
for (int cc = 0 ; cc < 14 ; cc++)
if (aa[cc] == bb[cc])
fg++;
if (fg == 14)
ff = true;
return ff;
void checkmytags() // compares each tag against the tag just read
ok = 0; // this variable helps decision-making,
// if it is 1 we have a match, zero is a read but no match,
// -1 is no read attempt made
if (comparetag(newtag, tag1) == true)
ok++;
if (comparetag(newtag, tag2) == true)
ok++;
void readTags()
ok = -1;
// read tag numbers
delay(75); // needed to allow time for the data to come in from the serial buffer.
for (int z = 0 ; z < 14 ; z++) // read the rest of the tag
data1 = RFID.read();
newtag[z] = data1;
RFID.flush(); // stops multiple reads
// do the tags match up?
checkmytags();
// now do something based on tag type
if (ok > 0) // if we had a match
Serial.println("Accepted");
digitalWrite(yes, HIGH);
digitalWrite(yes, LOW);
ok = -1;
else if (ok == 0) // if we didn't have a match
Serial.println("Rejected");
digitalWrite(no, HIGH);
digitalWrite(no, LOW);
ok = -1;
readTags();
Thanks for reading!
