Serial working from FTDI but not from second arduino
I’m having a little trouble with some code on an Arduino pro mini which works fine when I feed it serial commands using my FTDI cable however this is just for testing. I really want to send the commands from a controller made from an arduino uno. The problem is when I to send commands using the second arduino it doesn’t work. I viewed the data coming from the second arduino and it appears to be identical to what I sent via the FTDI cable.
My code is pretty long but so I’ll just include what I think are the important snippets.
My code on the pro mini is:
void serialEvent() {
  while (Serial.available() > 0) {
    char recieved = Serial.read();  // Receive byte
        receive_id += recieved;     // Add to id string
  if (receive_id == "F936"){        // Check if id is correct
    Serial.print("id");
    while(command_val == 0x00){     // Wait for the command
      if (Serial.available()) {
        command_val=Serial.read();
        if (command_val == '\n')    // Clear id strin when 0A received
          Serial.print("gotn");
            receive_id = "";        // Clear id strin
            command_val = 0x00;     // Clear command
    if(command_val<0x05){           // If command <05 wait for associated data
      Serial.print("com");
      while(data_val == 0x00){
          Serial.print("dat");
          data_val=Serial.read();
  else if (recieved == '\n'){      // If 0A received then wrong id
              receive_id = "";     // Clear id string
And the controller code is:
y1_val = analogRead(A4);
  delay(5);
  left_speed = map(y1_val, 0, 1024, 0x00, 0xFF);
  //left_speed=0xFF-left_speed;
  delay(2000);
  Serial.write(0x46);  // F
    delay(2000);
  Serial.write(0x39);  // 9
    delay(2000);
  Serial.write(0x33);  // 3
    delay(2000);
  Serial.write(0x36);  // 6
  delay(2000);
  Serial.write(0x0A);  // \n
  delay(2000);
  Serial.write(0x01);  // Command to enter drive mode
  delay(2000);
  Serial.write(left_speed);  // Drive value
 delay(2000);
  y2_val = analogRead(A1);
  delay(5);
  right_speed = map(y2_val, 0, 1024, 0x00, 0xFF);
  //right_speed = 0xFF-right_speed;
delay(2000);
Serial.print("F936");  // F936
delay(2000);
delay(2000);
Serial.write(0x02);  // Command to enter steering mode
  delay(2000);
  Serial.write(right_speed);  // Steering value
  delay(2000);
Is there something obvious I’m doing wrong here?
You have Rx to Tx, Tx to Rx, and Gnd to Gnd?
Yes and to be sure I connected the FTDI cable to the rx of the pro mini and I could see the data coming from the uno tx
How does this value get set before it gets to this line?
Maybe the logic is good, and I'm just seeing it funny.
At the start of the code I have
byte command_val = 0x00;
Once a command value greater than 0x00 is received, it carries out the command and then is once again returned to 0x00 with the following line
command_val = 0x00;
I think I may have some dinner, let the battery recharge and check my wiring again. Maybe I'll spot something after I've taken a break :)
Sounds like a good plan, it has worked for me in the past.
