Serial wound't send last character ?
Hello,
I want to send some data with a checksum at the end.
I always used the switch case to get my data over to an other device. before I did send a number and a letter that tells me what it is used for (for example "1245a")
I always get the same problem...
I send something but I wound be displayed until I send something after that and that will be only displayed when I send something after that and so on...
Arduino >>>>>>>>>>>>>> Processing
100b >>>>>>>>>>>>>>>>
100b111c >>>>>>>>>>>> 100b
100b111c7>>>>>>>>>>>> 100b111c and so on...
until now I did send the last value double so that it gets send but that is not a good way.
I get the same problem with the "new checksum way" so it must have something to do with the switch case ?
I hope someone understands me and can help me ^^
here is a little sketch I did on a Arduino Mega and Processing:
Arduino:
const int Size = 40;
int Array[Size];
int Data[Size];
unsigned long check =4;
unsigned long confirmed = 0;
  Serial.begin(57600); // put your setup code here, to run once:
  Serial3.begin(57600); // put your setup code here, to run once:
  serial();
//  for(int i = 0; i < Size; i++){
//    Serial.print(Data[i]);
//    Serial.print(",");
    Serial.print(confirmed);
    Serial.println("   End");
    delay(3);
void serial(){
  static int v = 0;
  static int i = 0;
  if ( Serial3.available() >= 2) { /// achtung serial "3"  !!!!
    char ch = Serial3.read();/// achtung serial "3"  !!!!
    if ( ch >= '0' && ch <= '9') {
      v = v *10 + ch - '0';
      switch(ch)
        //----------------|right side|-----------------------------------
      case ',':
        Array[i] = v;
        check   += v;
        i++;
      case '
Processing:
import processing.serial.*;
  int o = 0;
Serial port;
void setup(){
  println(Serial.list());
  port = new Serial(this, Serial.list()[0], 57600);
void draw(){
  port.write(o+","+1+","+1+","+1+","+1+","+1+","+1+","+1+","+(7+o)+"$");
  println(o+","+1+","+1+","+1+","+1+","+1+","+1+","+1+","+(7+o)+"$");
  o++;
  delay(150);
        if(check == v){
          for(int j = 0; j < Size; j++){
            Data[j] = Array[j];
        i = 0;
        confirmed = check;
        check = 0;
      v=0;
Processing:
§DISCOURSE_HOISTED_CODE_1§
![Checksum.PNG|708x300](upload://f8hDmxAzQleY2Jn7fJq4uOmbRXT.png)
You are checking, on the Arduino, that there are at least two characters to read. Then, you only read one. Why?
Well, now we know why.
