Serial.write() datatype issue in application @ xbee(API frame)
[u]Project overview[/u]: (This is programming prob not a xbee prob), I have 5 int values which i want wirelessly send to another xbee. "My problem is how to give hexvalues(0x4E) in Serial.write() when i have an integers values(say current, voltage etc) ??"
[u]What i did till now[/u]:
void loop(){
  int RP= 1391;
  int AP= 1581;
  int PF= 88;
  int V= 25500;
  int I= 62;
  char RPh= char(bitDividerhigh(RP));
  char RPl= char(bitDividerlow(RP));
  char APh= char(bitDividerhigh(AP));
  char APl= char(bitDividerlow(AP));
  char PFh= char(bitDividerhigh(PF));
  char PFl= char(bitDividerlow(PF));
  char Vh= char(bitDividerhigh(V));
  char Vl= char(bitDividerlow(V));
  char Ih= char(bitDividerhigh(I));
  char Il= char(bitDividerlow(I));
  Serial.write(0x7E);
  Serial.write((byte) 0x0);
  Serial.write(0x18);
  Serial.write(0x10);
  Serial.write(0x01);
  Serial.write(0xFF);
  Serial.write(0xFE);
  Serial.write(RPh);// issue here
  Serial.write(RPl);// issue here
  Serial.write(APh);// issue here
  Serial.write(APl);// issue here
  Serial.write(PFh);// issue here
  Serial.write(PFl);// issue here
  Serial.write(Vh);// issue here
  Serial.write(Vl);// issue here
  Serial.write(Ih);// issue here
  Serial.write(Il);// issue here
  long sum= 0x10 + 0xFF + 0xFF + 0xFF + 0xFE + RPh + RPl + APh + APl + PFh + PFl + Vh + Vl + Ih + Il;
  Serial.write( 0xFF - (sum&0xFF));
  delay(100);
int bitDividerhigh(int  input){
  int b= 65280;
  int c= input&b;
  int d= c>>8;
  return d;
int bitDividerlow(int input){
  int e= 255;
  int f= input&e;
  return f;
[u]Issue[/u]: I have indicated as comments in the code where i think, the data type i gave isn't the same as what its supposed to be. "Simply put just tell me, how to convert this integer values values into RF data that's perfectly compatible with Serial.write()??"
[u]Note[/u]: I am from electrical background, so much programming technical talk can confuse me :sweat_smile: , please try to provide some code to solve my issue( My coding knowledge can be judged from above code, its not a copy&paste). Thank you !!!
  int b= 65280;
  int c= input&b;
  int d= c>>8;
  return d;
  int e= 255;
  int f= input&e;
  return f;
Why reinvent the wheel?
What’s wrong with “lowByte” and “highByte”?
I have indicated as comments in the code where i think, the data type i gave isn’t the same as what its supposed to be
I don’t know what that means.
If you think you have used the wrong datatype, then you will have to fix it - the compiler will simply do what it is told to do.
First thing, i don't have coding in my curriculum and secondly, i learnt everything by myself. My hands on experience in arduino is comparably low to matlab(Machine learning and etc).
I am a hardcore electrical engineer, hardcore in the sense not just simple electric circuits. After 5 day long struggle and completely reading the Zigbee protocol and along with xbee.h+ some data handling logic i found in internet, i completed it.
I don't know that lowByte and highByte even exists, I am sorry because i never did coding seriously when i am in 8th standard? ( :P , that's a very long time ;) )
