Serial.write() hexadecimal value
I'm looking at this code that sends a hexadecimal value to a serial device.
Serial.write(0xAA);
I'm learning to port code to pure c on a microcontroller. The uart write function declaration for the microcontroller is below. It says that it performs a
single character write
. Is the hexadecimal value a single character.
Does this mean that you can can this function as
ti_uart_write(QM_UART_0, 0xAA);
 * Perform a single character write on the UART interface.
 * This is a blocking synchronous call.
 * @brief UART character data write.
 * @param [in] uart UART index.
 * @param [in] data Data to write to UART.
 * @return ti_rc_t QM_RC_OK on success, error code otherwise.
ti_rc_t qm_uart_write(const ti_uart_t uart, const uint8_t data);
No. It is a single byte. Any code that outputs binary data and talks about chars was written by someone I would not trust.
Knowing one (incorrect) phrase from the function description is NOT a basis for making that assumption.
Besides Paul’s comments, which are on a more philosophical level,
of course you can write
  qm_uart_write(QM_UART_0, 0xAA);
0xAA is a perfect value for a const uint8_t parameter.
Thank you for your help.
