Hey all,
I'm working on a project with arudino and a servo. Basically, the arduino turns the servo, and sends a signal back to the PC when it's done turning. I'm using this adaptation of the servo library: GitHub - netlabtoolkit/VarSpeedServo: Arduino library for servos that extends the standard servo.h library with the ability to set speed, and wait for position to complete.
The weird thing is I seem to be getting different responses from the Arduino for no apparent reason, and me plus some coworkers I talked with are kinda baffled.
The piece of arduino code responsible is this (nb. myservo is a class of VarSpeedServo, not entire code is included):
while (Serial.available() <= 0) {
serialInput = Serial.read();
if (serialInput >= 0 && serialInput <= 180){
// if legit number for Servo, make turns
myservo.write(serialInput, 10); // serialInput is degrees to turn servo, 10 is the speed.
delay(15);
myservo.wait(); // wait for servo to finish turning
Serial.write(45); // send back a random number, I just picked 45
On the PC (running octave) I test this with a simple command followed by a while loop waiting for responses (nb. Servo is a class with methods for turning the servo, and properties about the servo):
response = [];
Servo.Turn();
while isempty(response)
response = srl_read(Servo.port,1) % read 1 byte and display in commandline
end
I get different responses:
- Servo starts to turn, octave commandline is filled with response = [], because nothing is read. After servo is done, it displays response = 45. This should be the correct response
- Same as above, but instead of 45, i get response = 52. Happened on several occasions now.
- Same as above, but there never is a response = 45. Commandline keeps filling with response = []. writing (on Arduino) or reading (in octave) seems to fail?
- Immediately as the servo starts turning response = 45 is displayed. As if the myservo.wait is skipped. This seems to be persistent and if this happens, it keeps happening until octave is restarted.
I don't see a correlation between anything I do on the PC, except that restarting octave seems to change something. I also looked at the serial-monitor, to see if this responds differently from the srl_read in octave, but this behaves the same as srl_read-ing in octave.
I am already reworking my setup to not include this (time constraints), but still I want to know what is going. It almost feels like the Arduino is just messing with me.
Any thoughts or remarks are greatly appreciated.
