Serial.Write to GEETECH Voice Recognition Module
Hi all.
I ran the code given below on my Arduino Uno and then interfaced it with "GEETECH Voice Recognition Module" (user manual attached below).
The VR module successfully reads my Serial.Write command given in void setup() but not in void loop()!
After the Serial.write(0x21) command in void setup(), VR module successfully imports group 1 of my voice instructions.
But (for example) in Case 0x11 in void loop(), it is supposed to import group 2 of my voice instructions so that I gain access to case 0x21, case 0x22, case 0x23, it is not doing that!
   pinMode(2, OUTPUT);
   pinMode(3, OUTPUT);
   pinMode(4, OUTPUT);
   pinMode(5, OUTPUT);
   pinMode(6, OUTPUT);
   pinMode(7, OUTPUT);
   pinMode(8, OUTPUT);
   pinMode(9, OUTPUT);
   pinMode(10, OUTPUT);
   pinMode(11, OUTPUT);
   pinMode(12, OUTPUT);
   pinMode(13, OUTPUT);
   delay(2000);
   Serial.write(0xAA);
   Serial.write(0x37);
   Serial.write(0xAA);
   Serial.write(0x21);
   byte k = 0;
   byte led = 0;
   byte com = 0;
   while(Serial.available())
      com = Serial.read();
      switch(com)
         case 0x11:
         Serial.write(0xAA);
         Serial.write(0x22);
         digitalWrite(2,HIGH);
         digitalWrite(3, LOW);
         digitalWrite(4, LOW);
         k=1;
         case 0x12:
         Serial.write(0xAA);
         Serial.write(0x22);
         digitalWrite(2, LOW);
         digitalWrite(3, HIGH);
         k=4;
         case 0x13:
         Serial.write(0xAA);
         Serial.write(0x22);
         digitalWrite(4, HIGH);
         k=7;
         case 0x14:
         digitalWrite(5, LOW);
         digitalWrite(6, LOW);
         digitalWrite(7, LOW);
         digitalWrite(8, LOW);
         digitalWrite(9, LOW);
         digitalWrite(10, LOW);
         digitalWrite(11, LOW);
         digitalWrite(12, LOW);
         digitalWrite(13, LOW);
         case 0x15:
         case 0x21:
         Serial.write(0xAA);
         Serial.write(0x23);
         led = k+1;
         case 0x22:
         Serial.write(0xAA);
         Serial.write(0x23);
         led = k+2;
         case 0x23:
         Serial.write(0xAA);
         Serial.write(0x23);
         led = k+3;
         case 0x24:
         Serial.write(0xAA);
         Serial.write(0x21);
         case 0x25:
         case 0x31:
         digitalWrite(led, HIGH);
         case 0x32:
         digitalWrite(led, LOW);
         case 0x33:
         Serial.write(0xAA);
         Serial.write(0x22);
         case 0x34:
         case 0x35:
         default:
User Manual.pdf (604 KB)
Where does the serial input come from ? Are you sure that the com variable has the values that you expect ?
I know that the serial.write(0x21) (which is the hex command to import group1) works because case(0x11), case(0x12), case(0x13) are successfully accessed and corresponding LEDs light up. So the com variable has the right values here.
BUT
The serial.write(0x22) (which is the hex command to import group2) in the above mentioned cases under void loop(), does not seem to execute as I don't gain access to case(0x21), case(0x22), case(0x23).
It is stuck in group 1. I know this because only cases corresponding to group 1 are being accessed. Untill and unless serial.write(0x22) or serial.write(0x23) commands is read by my VR module, I cant instruct it any further and I'll stay stuck in group 1.
To summarise :
You say that the Arduino is receiving the correct values for the com variable
Therefore the Arduino is sending the correct values
My conclusion would be that there is a problem with the VR unit
What happens if you write a simple program to send commands to the VR unit ? Does it do what is expected ?
Thanks for help. I am trying out easier codes first and try to understand what exactly is happening. If I figure it out or need some help, I'll get back to you!
That sounds like a good plan.
Before importing Group 2 you need to give the 'waiting' instruction to VR module. The Instruction is AA 00, meaning Serial.write(0xAA) and Serial.write(0x00). Then give the instruction to import group 2. It will work.
