I want to send what this function print on serial monitor
To be sent via bluetooth to mobile app.
get_RFID_name that function
Should i be using something like
Serial.write ( buffer , len );
If so what should the paramters be
If not how can i ?
// Bluetooth
#include <SoftwareSerial.h>
SoftwareSerial HC05(2,3) ;
String data ;
int Data;
// RFID
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
// Init array that will store new NUID
byte nuidPICC[4];
int R_Forward = 5;
int R_Backward = 8;
int L_Forward = 6;
int L_Backward = 7;
Serial.begin (9600) ;
HC05.begin (9600) ;
//Right wheel
pinMode (R_Forward,OUTPUT) ;
pinMode (R_Backward,OUTPUT) ;
//Left wheel
pinMode (L_Forward,OUTPUT) ;
pinMode (L_Backward,OUTPUT) ;
SPI.begin(); // Init SPI bus
rfid.PCD_Init(); // Init MFRC522
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
if (HC05.available()>0) {
data = HC05.readString() ;
Data = data.toInt();
// Serial.println (Data);
switch (Data)
case 1:
Forward ();
Serial.println("Forward");
case 2:
Left ();
Serial.println("Right");
case 3:
Stop ();
Serial.println("Left");
case 4:
Right ();
Serial.println("Backward");
case 5:
Backward ();
Serial.println("Stop");
case 6:
get_RFID_name ();
void get_RFID_name ()
// Look for new cards
if ( ! rfid.PICC_IsNewCardPresent())
return;
// Verify if the NUID has been readed
if ( ! rfid.PICC_ReadCardSerial())
return;
for (byte i = 0; i < 4; i++) {
nuidPICC[i] = rfid.uid.uidByte[i];
printHex(rfid.uid.uidByte, rfid.uid.size);
rfid.PICC_HaltA();
rfid.PCD_StopCrypto1();
void printHex(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
