Serial writing to 7 segment display
For reasons I'm not sure of myself, I decided to try to use a Tiny as a base for a 4 digit countdown timer.
What I'm attempting is to break the countdown value into minutes, tens and units and seconds, tens and units. These digits form a stream to a 4518 counter the output of which would drive a 4511 to the display.
The appropriate CC is activated for a short period and the counter is reset between each digit and persistence of vision should give the impression of a constant display. Both chips are fed by separate 5v supply and everything is grounded together.
To prove the feasibility I'm starting with an Uno R3 clone to make changes easier.
The theory seems to work ONLY up to 2 digits. When I try to introduce a 3rd digit the whole display becomes nonsense although the program still seems to run. In trying to identify the problem I've swapped over the program cases and the physical connections. Everything seems to work independently using any 2 digits to any display, with the third case commented out. Could this be a timing issue?
Drawing attached.
Could anyone please shed any light on the cause?
unsigned long seconds = millis()/1000;
int pulse = 0;
int digit = 1;
int countDown = 120;  // Counting down 2 minute
unsigned long lastTick;
  pinMode(2, OUTPUT);   // pulsed output for display value
  pinMode(7,OUTPUT);    // reset for counter (active low)
  pinMode(8,OUTPUT);    // cc output display1
  pinMode(9,OUTPUT);    // cc output display2
   pinMode(10,OUTPUT);    // cc output display3
  digitalWrite(7, HIGH);  //reset for counter
void loop(){                                    // countdown and call display
  if(currentMillis - lastTick >= 1000){
    countDown--;
    lastTick += 1000;
      showdisplay();
void showdisplay() {
unsigned countMin = (countDown / 60);             // calc No of minutes
unsigned countSec = (countDown % 60);             // calc No of seconds
unsigned countMinUnit = (countMin / 1U) % 10;     //get minutes units
unsigned secUnits = (countSec / 1U) % 10;         // get seconds units
unsigned secTens = (countSec / 10U) % 6;        // get seconds tens
 for (int digit=1; digit <4; digit++) {             // count through 3 displays
      switch (digit) {                            // get case for each digit of display
          case 1:                                     // seconds units
             digitalWrite(7, LOW);                  //set counter (active low)
  for (pulse = 0; pulse < secUnits; pulse++){        // set the number of pulses to clock
  digitalWrite(2, HIGH);                           // rising pulse
  digitalWrite(2, LOW);                           // falling pulse
}                                                  // next pulse
                                                    // once count has been made activate display for that digit
           digitalWrite(8, LOW);                          // connect 0v to cc of display 1
      delay(10);                                     // time to show? try various
       digitalWrite(8, HIGH);                         // remove 0v from cc 1 (darken display)
      digitalWrite(7, HIGH);                        // reset counter
              case 2:                                    //seconds tens
         digitalWrite(7, LOW);                      // set counter (active low)
  for (pulse = 0; pulse < secTens; pulse++){        // set the number of pulses to clock
}                                                     // next pulse
         digitalWrite(9, LOW);                          // connect 0v to cc of display 2
         digitalWrite(9, HIGH);                         // remove 0v from cc 1 (darken display)
          case 3:                                 //minutes units
  for (pulse = 0; pulse < countMinUnit; pulse++){        // set the number of pulses to clock
}                                                  // next pulse
     digitalWrite(10, LOW);                          // connect 0v to cc of display 2
     digitalWrite(10, HIGH);                         // remove 0v from cc 1 (darken display)
(mod edit)
Where is the voltage being supplied from and is there a common ground ?
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Thanks for the reply. Sorry about posting in the wrong topic.
The Uno is powered from the usb and the 2 IC's are powered from a separate 5v supply (reads 5.15v and doesn't seem to drop when the program is running.
The Uno ground is linked to the breadboard ground.
