Serial Writting
Hi all, i am using a simple vb script to write to an arduino board, ie live commands
SerialPort1.Open()
SerialPort1.Write("1")
SerialPort1.Close()
what im trying to do is have the written commands from the vb program turn on a digital pin
this is my attempt in the arduino sketch book
Opening the serial port resets the Arduino.
Closing the serial port resets the Arduino.
If you are executing those commands in a script, with no delay between, don't expect the Arduino to actually do anything.
You need more code than that. You need at least a setup() and loop() functions.
sry forum cut me off didnt know it posted
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
pinMode(13, OUTPUT);
int incomingByte;
incomingByte = Serial.read();
if (incomingByte=="1"{
digitalWrite(13,HIGH);
Come on back when you have a sketch that will compile.
You need to check the difference between a character (single quotes) and a string (double quotes)
 int incomingByte; incomingByte = Serial.read();
I've never really understood this style of programming
int incomingByte;
if (incomingByte==1){
Still not right. Read AWOL's comment again.
thank you guys, been a while since ive programmed in java forgot that difference, its working :slight_smile:
Unless you are doing that somewhere else, the timer hasn't reset. The Arduino is programmed in C++.
