Serial xpos from Processing to Arduino for DC moto
I am trying to send the serial data of the xpos of a ficudial ID being video-captured in Processing to Arduino to control a dc motor with an encoder. I am using A Big Magnet's code for dc motor control with potentiometer, except I switched out the potentiometer for my serial data of the xpos from processing. I have gotten the PID control to make the speed of the motor change according to how large the # value of the serial data is, but I need it to change direction and have the position of the dc motor correspond to the xpos in processing. Does this make sense?? The video recognition is ReacTIVision -> Processing, processing serial-> arduino. here is the arduino code I am using, the processing is just port.write(x); and println(x); in the class for updating the position of the ID, any help is greatly appreciated I'm totally lost:
#include <AFMotor.h>
AF_DCMotor motor(1, MOTOR12_8KHZ);
#define encoder0PinA 2
#define encoder0PinB 3
volatile int encoder0Pos = 0;
//correction = Kp * error + Kd * (error - prevError) + kI * (sum of errors)
//PID controller constants
float KP = 1; //position multiplier (gain)
float KI = .5; // Intergral multiplier (gain)
float KD = 1; // derivative multiplier (gain)
//track the previous error for the derivitive term, and the sum of the errors for the integral term
int lastError = 0;
int sumError = 0;
//Integral term min/max (random value and not yet tested/verified)
int iMax = 255;
int iMin = 0;
pinMode(encoder0PinA, INPUT);
pinMode(encoder0PinB, INPUT);
// attach interrupt service routine (ISR) to the encoder pins
attachInterrupt(0, doEncoderA, CHANGE);
//to use the full 4x encoding uncomment out the other ISR attachment
//attachInterrupt(1, doEncoderB, CHANGE);
pinMode(13, OUTPUT);
if (Serial.available()>0) {
int val = Serial.read();//(0-300)
Serial.flush();
int target = map(val,0,255,0,3600);
int error = encoder0Pos - target; // find the error term of current position - target
// generalized PID formula
int ms = KP * error + KD * (error - lastError) + KI * (sumError);// calculate a motor speed for the current conditions
// set the last and sumerrors for next loop iteration
lastError = error;
sumError += error;
//scale the sum for the integral term
if(sumError > iMax){
sumError = iMax;
else if(sumError < iMin){
sumError = iMin;
int direction;
if(ms > 0){
direction = BACKWARD;
digitalWrite(13,LOW);
if(ms < 0){
direction = FORWARD;
digitalWrite(13,HIGH);
ms = -1 * ms;
int motorSpeed = map(ms,0,255,0,255);//i just put 255 for both since I'm not sure what values these would be
motor.setSpeed(100);
motor.run(direction);
//ISR functions
void doEncoderA(){
// look for a low-to-high on channel A
if (digitalRead(encoder0PinA) == HIGH) {
// check channel B to see which way encoder is turning
if (digitalRead(encoder0PinB) == LOW) {
encoder0Pos = encoder0Pos + 1; // CW
else {
encoder0Pos = encoder0Pos - 1; // CCW
// look for a high-to-low on channel A
if (digitalRead(encoder0PinB) == HIGH) {
else {
void doEncoderB(){
// look for a low-to-high on channel B
// check channel A to see which way encoder is turning
else {
// Look for a high-to-low on channel B
else {
if (digitalRead(encoder0PinA) == LOW) {
else {
