Serial1.prinln prints my host truncated for sim900 GSM shield
I am using GSM shield to send http request. however when I serial1.println my url, it gets truncated:
here is my code:
#include <String.h>
  Serial1.begin(19200);               // the GPRS baud rate
  Serial.begin(19200);    // the GPRS baud rate
  //after start up the program, you can using terminal to connect the serial of gprs shield,
  //if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
  //if input 'd' in the terminal, it will execute DialVoiceCall(), etc.
  if (Serial.available())
    switch(Serial.read())
     case 'h':
       SubmitHttpRequest();
  if (Serial1.available())
    Serial.write(Serial1.read());
///SubmitHttpRequest()
void SubmitHttpRequest()
  Serial1.println("AT+CREG?");
  delay(100);
 // Serial1.println("+CREG: 0,1");
//  delay(100);
  ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too.
  Serial1.println("AT+CGATT?");
  delay(100);
  ShowSerialData();
  Serial1.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");//setting the SAPBR, the connection type is using gprs
  ShowSerialData();
  Serial1.println("AT+SAPBR=3,1,\"APN\",\"my3g\"");//setting the APN, the second need you fill in your local apn server
  delay(4000);
  ShowSerialData();
  Serial1.println("AT+SAPBR=2,1");//setting the SAPBR, for detail you can refer to the AT command mamual
  delay(2000);
  ShowSerialData();
  Serial1.println("AT+HTTPINIT"); //init the HTTP request
  delay(2000);
  ShowSerialData();
  Serial1.println("AT+HTTPPARA=\"CID\",1");
 ShowSerialData();
 String urlString = "AT+HTTPPARA=\"URL\",\"http://11.111.111.11:8080/api/v1/qwertyuiopasdfghjklz/telemetry\"";
  Serial1.println(urlString);// this is not working !!
  delay(3000);
ShowSerialData();
//  Serial1.println("AT+HTTPPARA=\"CONTENT\",\"application/json\"");
 Serial1.println("AT+HTTPPARA= 19,10000");
 Serial1.println("{\"key\":\"arduino58\"}");
 ShowSerialData();
  Serial1.println("AT+HTTPACTION=1");//submit the request
  delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer.
  //while(!Serial1.available());
  ShowSerialData();
  Serial1.println("AT+HTTPREAD");// read the data from the website you access
  delay(300);
  ShowSerialData();
  Serial1.println("");
  delay(100);
void ShowSerialData()
  while(Serial1.available()!=0)
pay attention to the line:
 String urlString = "AT+HTTPPARA=\"URL\",\"http://52.187.135.25:8080/api/v1/qwertyuiopasdfghjklz/telemetry\"";
and when its printed in the serial again its something like:
AT+HTTPPARA="URL","http://52.187.135.25:8080/api/v1/qwertyuiopaAT+HTTPPARA= 19,10000
you see how it gets truncated!
for reference here is my compete output :
AT+CREG?
+CREG: 0,1
OK
AT+CGATT?
+CGATT: 1
OK
AT+SAPBR=3,1,"CONTYPE","GPRS"
OK
AT+SAPBR=3,1,"APN","my3g"
OK
AT+SAPBR=2,1
+SAPBR: 1,3,"0.0.0.0"
OK
AT+HTTPINIT
ERROR
AT+HTTPPARA="CID",1
OK
{"key":"arduino58"}
AT+HTTPACTION=1
AT+HTTPREAD
OK
string buffer 64 chars ?
Why store it in a variable ? Print it as two strings?
