Serial1 - Strange Behavior
Good evening, I''m using a serial1 and connected to it i ve my shield that i've done for send out message ...
but when i've connect it i cannot program my arduino ... with sync issues ...
and if i detach my shield i can program it ... when i connect it again my arduino start to reset each time ...
what could related ? for sure is related to my shield but could be the issues that cause the reset ?
is there someone that has encountered this issues ?
Thanks Andrea
Are you sure your shield use Serial1 (pins D18/D19) and not Serial0 (pins D0/D1) ?
hi thanks for the information ...
y3es im sure :-( ... but i will do a double check for that ...
thanks Andrea
Which Arduino ? Which shield ?
  • Arduino 2560
  • shield is my shield that i did for send out message like powerline ...
thanks Andrea
gnusso: - shield is my shield that i did for send out message like powerline ...
Can you post a complete schematic of your shield so we can see how it works with the Mega?
...R
Hi the fact, is working like normal tx / rx crossed ... with virtual wire library for example no issues with that ... but i would like to do a test with serial port,
thanks Andrea
gnusso: but i would like to do a test with serial port,
Did you see Reply #5 ?
...R
