Serial1.write((byte) 0x00)
Hello,
I use UART binary communication channel on 33iot. All works fine except transmitting zero byte 0x00. I have read few other threads on related topics and they suggested to include explicit (byte) typing to avoid misinterpretation with null string termination.
However even explicit Serial1.write((byte) 0x00) does not send anything. All other non-zero values are being sent OK.
any hints?
thanks
Jan
Start by posting an example sketch that illustrates the problem, using code tags when you do
What is receiving the data that you transmit ?
This is a part of large project that I cannot post here. However I am sure that all other aspects (eg. UART serial connection initialisation, all HW aspects, etc.) are working OK. I was able to isolate the problem to this single code line:
Serial1.write((byte) 0x01) ... works OK and correctly sends the byte
Serial1.write((byte) 0x00) ... does not send anything
the UART communication is between Arduino and other microcontroller (based on xmc4200)
Jan
How do you know that nothing is sent ?
Are you absolutely sure that the problem is not at the receiving end ?
I am sure by both, observing the receive register on xmc4200 side (by attached debugger) and by observing the UART Tx line by oscilloscope.
Then something else is wrong
Running this sketch on a Nano 33 IOT
  Serial1.begin(9600);
  Serial1.write((byte)0x0);
and this sketch on a Nano classic
  if (Serial.available())
    Serial.println("got a byte");
    Serial.read();
prints the "got a byte" message every second as expected
The two Nanos have a common GND connection and the boards are connected by a single wire from the TX1 pin on the 33 to the Rx pin on the classic. I did not bother with a voltage level shifter because of the direction of the transmission from 3V3 to 5V
are you sending binary data or ASCII? ASCII char strings are by convention terminated with a NUL, 0x0
something that delimits the start and end of binary data is required such as start and end values. those values need to be escaped if sent as data, usually by preceding them with an escape value, which also needs to be escaped when sent as data
