Hi All,
I have an Arduino mega, it's connected to an electric imp breakout board. I have Serial3 connected on:
MEGA IMP BREAKOUT
RX (15) -> PIN 1 (TX)
TX (14) -> PIN 2 (RX)
on the breakout board (details on the board can be found https://www.maker.io/en/projects/electric-imp-breakout-hookup-guide/0bbf34e37ef545948d6664c51555fd01 It is the one with 9 pins, not the shield).
I have the code set up, but I don't see any activity on the RX/TX light, nor anything getting sent over the imp. I've cut down my code to this as that is all I am using at the moment.
void setup () {
Serial3.begin(19200);
void loop () {
Serial3.write(7);
Alarm.delay(1000);
I would expect to see some activity on the RX/TX lights on the mega board, but nothing. I also don't see anything in the imp web interface as I would expect.
Everything is connected to a common ground and the imp is using the 3.3v from the Arduino to power it. It's connected fine to the internet and I can see if in the IDE.
How can I see if anything is being sent? Or, am I using it wrong? Has anyone got an advice on how I should be sending data using this board?
Thanks all.
