Hi all,
I'm trying to develop a dual GPS serial logger with continues streams of data using a SAMD21.
A second Serial has been set up in the variants.h using a free sercom.
Both modules can run on various baudrates, using 460800 atm.
Communication to both modules works fine.
I'm having trouble with understanding how the internal serial ringbuffer works for different ports.
The stream of data from the first port is printed fine, while the second overflows at the size of serial_buffer from Ringbuffer.h
Increasing the size of the ringbuffer helps a bit, but still not all data is being received from the second port.
#include <Arduino.h>
#define BASE Serial1
#define ROVER Serial2
#define GPS_BAUD 460800
#define CONSOLE_STREAM SerialUSB
#define CONSOLE_BAUD 115200
#define READ_TIMEOUT_MS 2
#define BUFFER_SIZE 4096
uint8_t buffer[BUFFER_SIZE];
BASE.begin(GPS_BAUD);
ROVER.begin(GPS_BAUD);
CONSOLE_STREAM.begin(CONSOLE_BAUD);
// BASE -> Console
CONSOLE_STREAM.print("\n\n\rBASE: ");
memset(buffer, 0, BUFFER_SIZE);
writeConsole( readSerialStream((Stream*)&BASE) );
// ROVER -> Console
CONSOLE_STREAM.print("\n\n\rROVER: ");
writeConsole( readSerialStream((Stream*)&ROVER) );
size_t readSerialStream(Stream* stream)
uint32_t last = millis();
size_t count = 0;
while ((count < BUFFER_SIZE) && (millis() < (last + READ_TIMEOUT_MS))) {
if (stream->available()) {
buffer[count++] = stream->read();
last = millis();
CONSOLE_STREAM.println(count);
return count;
void writeConsole(size_t count)
if (count > 0) {
for (size_t i = 0; i < count; i++) {
CONSOLE_STREAM.print((char)buffer[i]);
Below a single read of both receivers:
- The data aquired from the BASE module is as expected.
- The data aquired from the ROVER module is capped at the buffer size. (overflow)
BASE Bytes: 1886
$GNRMC,175823.00,A,XXXX.XXXXX,N,XXXXX.XXXXX,E,0.023,,200320,,,A,V*16
$GNVTG,,T,,M,0.023,N,0.042,K,A*3A
$GNGGA,175823.00,XXXX.XXXXX,N,XXXXX.XXXXX,E,1,12,0.62,3.6,M,46.0,M,,*42
$GNGSA,A,3,20,27,16,21,26,10,29,,,,,,1.09,0.62,0.89,1*01
$GNGSA,A,3,65,73,82,79,66,81,80,,,,,,1.09,0.62,0.89,2*0D
$GNGSA,A,3,27,01,13,15,21,,,,,,,,1.09,0.62,0.89,3*0F
$GNGSA,A,3,24,13,26,20,29,,,,,,,,1.09,0.62,0.89,4*00
$GPGSV,3,1,12,05,01,020,09,07,05,338,22,08,08,274,16,10,11,159,28,1*60
$GPGSV,3,2,12,16,69,278,35,18,42,059,34,20,33,136,33,21,65,077,37,1*63
$GPGSV,3,3,12,26,65,188,39,27,39,277,28,29,15,087,35,31,07,201,,1*6C
$GPGSV,3,1,12,05,01,020,,07,05,338,,08,08,274,,10,11,159,19,6*6B
$GPGSV,3,2,12,16,69,278,,18,42,059,27,20,33,136,,21,65,077,,6*64
$GPGSV,3,3,12,26,65,188,,27,39,277,,29,15,087,17,31,07,201,,6*6B
$GLGSV,3,1,10,65,20,030,24,66,17,094,32,72,03,352,,73,17,332,21,1*74
$GLGSV,3,2,10,79,30,187,29,80,60,263,22,81,51,048,27,82,66,277,35,1*73
$GLGSV,3,3,10,83,20,250,,88,08,060,25,1*7E
$GLGSV,3,1,10,65,20,030,,66,17,094,,72,03,352,14,73,17,332,,3*77
$GLGSV,3,2,10,79,30,187,,80,60,263,,81,51,048,30,82,66,277,26,3*7E
$GLGSV,3,3,10,83,20,250,,88,08,060,,3*7B
$GAGSV,3,1,09,01,23,316,25,03,04,089,,05,09,041,26,09,02,355,09,7*71
$GAGSV,3,2,09,13,66,231,30,15,57,062,31,21,63,264,30,26,13,236,25,7*79
$GAGSV,3,3,09,27,39,175,34,7*41
$GAGSV,3,1,09,01,23,316,,03,04,089,,05,09,041,,09,02,355,,*4C
$GAGSV,3,2,09,13,66,231,,15,57,062,,21,63,264,,26,13,236,,*4B
$GAGSV,3,3,09,27,39,175,,*71
$GBGSV,3,1,09,02,00,098,,05,15,119,,13,17,048,26,19,04,143,,1*70
$GBGSV,3,2,09,20,22,097,33,24,22,317,22,26,45,264,12,29,61,073,37,1*7B
$GBGSV,3,3,09,30,08,077,22,1*44
$GBGSV,3,1,09,02,00,098,,05,15,119,,13,17,048,,19,04,143,,*45
$GBGSV,3,2,09,20,22,097,,24,22,317,,26,45,264,,29,61,073,,*4D
$GBGSV,3,3,09,30,08,077,,*75
$GNGLL,XXXX.XXXXX,N,XXXXX.XXXXX,E,175823.00,A,A*77
ROVER Bytes: 255
$GNRMC,175823.00,A,XXXX.XXXXX,N,XXXXX.XXXXX,E,0.040,,200320,,,A,V*11
$GNVTG,,T,,M,0.040,N,0.074,K,A*3A
$GNGGA,175823.00,XXXX.XXXXX,N,XXXXX.XXXXX,E,1,12,0.59,17.5,M,46.0,M,,*7E
$GNGSA,A,3,21,27,16,20,26,29,10,,,,,,1.04,0.59,0.86,1*0B
$GNGSA,A,3,66,80,7
After reading the Serial Input Basics tutorials I've changed the readSerialStream function to:
size_t count = 0;
if (stream->available() > 0)
while ((stream->available() > 0) && (count < BUFFER_SIZE)) {
return count;
The output of the last function: (increased the serial_buffer_size to 1024)
BASE: 0
ROVER: 41
$GNRMC,225341.00,A,XXXX.XXXXX,N,XXXXX.XXX
BASE: 122
$GNRMC,225341.00,A,XXXX.XXXXX,N,XXXXX.XXXXX,E,0.056,,200320,,,A,V*12
$GNVTG,,T,,M,0.056,N,0.104,K,A*3B
$GNGGA,225341.00,
ROVER: 679
42,E,0.047,,200320,,,A,V*11
$GNVTG,,T,,M,0.047,N,0.087,K,A*31
$GNGGA,225341.00,XXXX.XXXXX,N,XXXXX.XXXXX,E,1,12,0.62,2.9,M,46.0,M,,*49
$GNGSA,A,3,01,03,11,14,28,08,22,32,17,,,,1.07,0.62,0.87,1*0E
$GNGSA,A,3,76,69,84,68,85,,,,,,,,1.07,0.62,0.87,2*0E
$GNGSA,A,3,31,26,33,24,07,08,13,,,,,,1.07,0.62,0.87,3*03
$GNGSA,A,3,09,06,12,16,21,22,,,,,,,1.07,0.62,0.87,4*01
$GPGSV,3,1,12,01,77,300,43,03,38,230,20,08,32,169,31,10,08,058,20,1*68
$GPGSV,3,2,12,11,66,147,42,14,43,097,31,17,18,316,18,22,66,225,35,1*6D
$GPGSV,3,3,12,24,02,005,22,27,05,155,05,28,26,289,29,32,37,065,36,1*67
$GPGSV,3,1,12,01,77,300,36,03,38,230,,08,32,169,30,10,08,058,17,6*6A
$GPGSV,3,2,12,11,66,147,,1
BASE: 1023
XXXX.XXXXX,N,XXXXX.XXXXX,E,1,12,0.60,19.8,M,46.0,M,,*73
$GNGSA,A,3,03,08,11,14,17,28,22,32,01,,,,1.05,0.60,0.86,1*0F
$GNGSA,A,3,76,68,84,83,69,85,,,,,,,1.05,0.60,0.86,2*04
$GNGSA,A,3,33,26,13,31,24,07,08,,,,,,1.05,0.60,0.86,3*02
$GNGSA,A,3,09,12,16,21,19,06,22,,,,,,1.05,0.60,0.86,4*08
$GPGSV,3,1,12,01,77,300,35,03,38,230,18,08,32,169,27,10,08,058,20,1*65
$GPGSV,3,2,12,11,66,147,31,14,43,097,32,17,18,316,25,22,65,225,33,1*61
$GPGSV,3,3,12,24,02,005,15,27,05,155,16,28,26,289,28,32,37,065,23,1*64
$GPGSV,3,1,12,01,77,300,31,03,38,230,16,08,32,169,26,10,08,058,18,6*62
$GPGSV,3,2,12,11,66,147,,14,43,097,,17,18,316,13,22,65,225,,6*60
$GPGSV,3,3,12,24,02,005,,27,05,155,,28,26,289,,32,37,065,29,6*60
$GLGSV,3,1,09,68,40,041,29,69,75,149,36,70,20,203,,75,06,289,19,1*78
$GLGSV,3,2,09,76,15,335,18,77,05,025,,83,18,128,,84,78,104,26,1*70
$GLGSV,3,3,09,85,39,316,28,1*48
$GLGSV,3,1,10,68,40,041,22,69,75,149,34,70,20,203,,75,06,289,,3*73
$GLGSV,3,2,10,76,15,335,20,77,05,025,,83,18,128,20,84,78,104,35,3*71
$GL
ROVER: 1023
4,43,097,,17,18,316,19,22,66,225,,6*69
$GPGSV,3,3,12,24,02,005,,27,05,155,17,28,26,289,,32,37,065,21,6*6E
$GLGSV,3,1,09,68,40,041,31,69,75,149,37,70,20,203,,75,06,289,22,1*78
$GLGSV,3,2,09,76,15,335,,77,05,025,,83,18,128,,84,78,104,20,1*7F
$GLGSV,3,3,09,85,39,316,24,1*44
$GLGSV,3,1,10,68,40,041,28,69,75,149,35,70,20,203,,75,06,289,,3*78
$GLGSV,3,2,10,76,15,335,22,77,05,025,,83,18,128,,84,78,104,35,3*71
$GLGSV,3,3,10,85,39,316,28,3*42
$GAGSV,3,1,10,07,57,103,31,08,24,045,24,12,07,297,19,13,14,118,36,7*76
$GAGSV,3,2,10,14,16,155,23,24,14,320,14,25,00,006,,26,67,120,16,7*76
$GAGSV,3,3,10,31,11,271,13,33,57,297,33,7*78
$GAGSV,3,1,10,07,57,103,,08,24,045,,12,07,297,,13,14,118,,2*7A
$GAGSV,3,2,10,14,16,155,,24,14,320,,25,00,006,,26,67,120,29,2*7B
$GAGSV,3,3,10,31,11,271,,33,57,297,,2*7F
$GBGSV,3,1,09,05,14,120,,06,20,037,25,09,36,059,31,12,75,189,36,1*7F
$GBGSV,3,2,09,16,26,042,31,19,12,048,,21,55,198,27,22,60,073,37,1*7E
$GBGSV,3,3,09,23,00,311,,1*4D
$GBGSV,3,1,09,05,14,120,,06,20,037,,09,36,059,
BASE: 0
ROVER: 0
Still overflowing the ring buffer and thus causing gaps in the data.
What could be an adequate solution to this issue?
