SerialBT not declared (though it should be)
i'm having some issues with the BluetoothSerial library, i'm pretty sure my code should be okay, but when i compile it, it says that SerialBT was not declared in this scope
here's my bluetooth configuration code: (my other code basically just runs those functions)
#include <BluetoothSerial.h>
void BT_setup(){
  BluetoothSerial SerialBT;
  SerialBT.begin("Luna", true);
void connection(){
  if(SerialBT.connect()){
    lcd.setCursor(3, 1);
    lcd.print("Connected!");
    int connection_status = 1;
    else{
    lcd.setCursor(0, 1);
    lcd.print("Connection error");
void connection() has the same problem as BT_setup()
the problem it spits out is:
C:\Users\Luna\Documents\Arduino\lcd_and_soundboard\BTSerial_config.ino: In function 'void connection()':
C:\Users\Luna\Documents\Arduino\lcd_and_soundboard\BTSerial_config.ino:16:6: error: 'SerialBT' was not declared in this scope
C:\Users\Luna\Documents\Arduino\lcd_and_soundboard\BTSerial_config.ino:16:6: note: suggested alternative: 'Serial2'
      Serial2
Multiple libraries were found for "BluetoothSerial.h"
  Used: C:\Users\Luna\Documents\Arduino\libraries\BluetoothSerial
  Not used: C:\Users\Luna\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.16\libraries\BluetoothSerial
exit status 1
Compilation error: 'SerialBT' was not declared in this scope
void BT_setup()
SerialBT is a local object in the BT_setup() function hence it is not accessible in other scopes
Make it a global instance instead
how do i make it global?
Create the instance of the object outside of any function just like any global variable
Please post a complete sketch should you have any further questions
i just tried
int BluetoothSerial SerialBT;
but i got the same error, did i do it right or did i completely get it wrong?
full sketch:
lcd_and_soundboard.zip (1,3,KB)
It is not an int variable or, indeed, a variable of any type. Remove the data type from the declaration
Did you miss my request ?
From this and your other topic it would seem that you need to read up on basic C/C++
just tried straight-up BluetoothSerial SerialBT; and it worked, thanks guys, also thanks for the tip! i'll read some C/C++ docs to see if i understand things better
I am glad that you got it working
