serialEvent() string reconstruction and interpreting issue.
Hello,
For my application I am communicating to a motor driver via the serial monitor by sending strings. To do this I am using a serialEvent() function to build the string before sending it off to Serial3. It looks something like this.
void serialEvent() {
  while (Serial.available()) {
    char inChar = (char)Serial.read();
    Command += inChar;
    if (inChar == '\n')
      commandComplete = true;
  if (commandComplete) {
      Serial3.print(Command);
    Command = "";
    commandComplete = false;
I am having an issue whereby I want to interpret the string and if the string is required to something (someAction), it does, else it sends the command to Serial3. Something like:
    if (Command == ("someAction") {
      //do someAction
    Command = "";
The problem is that the code (possibly the string reconstruction) cannot interpret the "someAction" string and immediately sends it off to Serial3. I am sure this problem has to do with data structure but I cannot figure it out. I also tried adding a line feed, but that is not working.
    if (Command == ("someAction" + '\n') {
      //do someAction
    Command = "";
Useless code ignored.
Something like:
More useless code ignored.
Post your real code.
(Why) (is) ("someAction") (in) (parentheses) (?)
Also, we don't know if you're using the String class (often unnecessary) or a character array for strings, but this statement:
is not the way to compare strings. Check out strcmp(). Post all of you code so we can see the data types and other structures you are using.
    Command += inChar;
    if (inChar == '\n')
You are adding the '\n' into Command and it is not included in "someAction"
And you are not adding a terminating 0 to mark the end of the received command.
Perhaps something like this
    if (inChar == '\n')
      Command += 0;
   else {
      Command += inChar;
...R
If the message is to be terminated with the newline character, why not use something like
#define MESSAGESIZE  20   // Whatever the size needs to be
char message[MESSAGESIZE  + 1];   // Room for terminating null
// setup() and loop() code...
// Code in loop()
int charsRead;
while (Serial.available() > 0) {
    charsRead = Serial.readBytesUntil('\n', message, MESSAGESIZE);
    message[charsRead] = '\0';   // Make it a string...
// rest of code
while?
