Serialmonitor input and returning reversed questionmark
hello!
My arduino uno is giving a constant flow of reversed questionmarks (or -1 in DEC) when looking for input. I have given commands trough the serialmonitor and through a HM10 BLE bluetooth device.
In the current state the arduino give a string of -1 until i give an input, and then stops.
I have changed the baudrate multiple times, tried with and with out both the motorshield and BLE.
the code:
#include <Adafruit_MotorShield.h>
#include <stdio.h>
//#include <SoftwareSerial.h>
//SoftwareSerial mySerial(2, 3); //RX,TX
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
//creates two objects to control two terminals on the motor shield
Adafruit_DCMotor *motor1 = AFMS.getMotor(2);
Adafruit_DCMotor *motor2 = AFMS.getMotor(1);
char val;
  Serial.begin(9600, SERIAL_8N1);  //Set the baud rate to your Bluetooth module.
   if(Serial.available() > 0)
      val = Serial.read();
         Serial.print("You typed: " );
          Serial.println(val, DEC);
  //if(Serial.read() != -1)
if(val=='F')  //when the bluetooth module recieves 1 the car moves forward
 //Serial.println("2");
 forward();
if(val=='B')  //when the bluetooth module recieves 2 the car moves backward
 backward();
if(val=='L') //when the bluetooth module recieves 3 the car moves left
 left();
if(val=='R')  //when the bluetooth module recieves 4 the car moves right
 right();
if(val=='S') //when the bluetooth module recieves 5 the car stops
 Stop();
void forward()
  motor1->setSpeed(100); //Define maximum velocity
  motor1->run(BACKWARD); //rotate the motor clockwise
  motor2->setSpeed(100); //Define maximum velocity
  motor2->run(FORWARD); //rotate the motor clockwise
  delay (500);
  motor1->setSpeed(220); //Define maximum velocity
  motor2->setSpeed(220); //Define maximum velocity
  Serial.println("1");
void backward()
  motor1->run(FORWARD); //rotate the motor counterclockwise
  motor2->run(BACKWARD); //rotate the motor counterclockwise
void left()
  motor1->run(FORWARD); //rotate the motor clockwise
  motor2->run(FORWARD); //turn motor2 off
void right()
  motor1->run(FORWARD); //turn motor1 off
void Stop()
  motor1->setSpeed(0);
  motor2->run(RELEASE); //turn motor1 off
  motor2->setSpeed(0);
  motor2->run(RELEASE); //turn motor2 off
this code worked before i tried to give the motor some rev-time, no its restored to the original (That worked)
Any and all help is much appriciated!!
in the above code, you test if available() and only read() if it is, but then continue to process val regardless. don't know what you intend the pair of braces to do
since the rest of loop() needs a valid value for val, there's nothing for it to do unless there is something available. so if nothing is available, return
   if(Serial.available() ==0)
       return;
If you read from serial when there is nothing there, -1 is what you get. The code you posted guards against this so I can't see how you're getting -1.
Although I don't have the motor shield, if I run your code I get a stream of zeros, not -1s.
I suspect that the code you posted is a different version from the one you took the screenshot with.
wildbill:
Thanks for your help, Yes the screenshot is with Serial.println(val, DEC); Instead of Serial.println(val); you are correct!
The thing is, the fact that its picking up, and sending the -1 (or reversed questionmark without DEC in the serialprint) makes the code to jump out of the loop. Im confused to say the least. From my Original original code:
char val;
  Serial.begin(9600);  //Set the baud rate to your Bluetooth module.
 forward();
 backward();
 left();
 right();
 Stop();
void forward()
  delay (500);
void backward()
void left()
void right()
void Stop()
everthing worked. Then when i started messing around with the void forward, void backward Etc i started getting the Reversed questionmarks on all code, as soon as i asked for a serial.read.
Thank you for taking your time to help out!
That version will indeed show the funky question mark. I see no reason why it would exit the loop though.
I can't test it due to lack of hardware, if I send F, the earlier version just hangs.
you only read if available, but print and process regardless
is this falling on deaf ears?
gcjr:
No mr gcjr, its not. The code worked moments before, but we took your advice, changed too ignore all the output from the arduino and work around it. It works great again. Thanks for the input!
