The output for the serial.print has a lot of Zeros in it, which kills my sensing of the rpm. But if I use the following instead of Serial.println(rpm1): Serial.println(double(double(enc_count1) * double(333333.33 / (timenew - timeold))));
it works, no zeros in it. But as I need the value of rpm1 for further calculations I would want it to print the same as calculated directly in serial.print.
Where are the zeros coming from?
thanks
/Users/john/Documents/Arduino/sketch_sep22a/sketch_sep22a.ino: In function 'void setup()':
/Users/john/Documents/Arduino/sketch_sep22a/sketch_sep22a.ino:7:19: warning: suggest parentheses around arithmetic in operand of '|' [-Wparentheses]
TCCR1B = TCCR1B & B11111000 | B00000001;
/Users/john/Documents/Arduino/sketch_sep22a/sketch_sep22a.ino: In function 'void loop()':
sketch_sep22a:12: error: 'set' was not declared in this scope
if (set == true) {
sketch_sep22a:13: error: 'timeold' was not declared in this scope
timeold = timenew;
sketch_sep22a:13: error: 'timenew' was not declared in this scope
timeold = timenew;
sketch_sep22a:15: error: 'rpm1' was not declared in this scope
rpm1 = double(double(enc_count1) * double(333333.33 / (timenew - timeold))); //60000000/180=333333,33
sketch_sep22a:15: error: 'enc_count1' was not declared in this scope
sketch_sep22a:20: error: 'PIN_OUTPUT' was not declared in this scope
analogWrite(PIN_OUTPUT, 100);
/Users/john/Documents/Arduino/sketch_sep22a/sketch_sep22a.ino: In function 'void count1()':
sketch_sep22a:25: error: 'set' was not declared in this scope
set = true;
sketch_sep22a:30: error: 'enc_count1' was not declared in this scope
enc_count1 = enc_count1 + lookup_table[enc_val1 & 0b1111];
exit status 1
As stated above, the code you posted is not complete and won’t compile. Please fix that.
I’m gonna guess that ‘set’ and ‘enc_count1’ are global and shared between the ISR and loop().
Make sure you declared them as volatile. Also, the block of code in loop() that accesses the shared variables should be surrounded by a noInterrupts() / interrupts() pair. Then, rearrange loop() so that you do the minimal amount of stuff while interrupts are disabled. Don’t use Serial.print() until interrupts are enabled again:
int tempCount;
unsigned long tempTime;
if (set==true) {
noInterrupts();
tempTime = millis();
tempCount = enc_count1;
set = false;
enc_count1 = 0;
interrupts();
timeold = timenew;
timenew = tempTime;
rpm = some function of tempCount, timeold, timenew;
Serial.println(rpm1);
you need to code what has been suggested in #4 about the interrupt as well. You have a critical section where you use things that can be modified behind your back during the math.
