How can i print it in a Serial monitor in 1 line only?
Output:
“Enter Date
Month = 12
day = 2
Year = 1
The Date is:
94”
Expected Output is:
Enter Date
Month = 12
day = 2
Year = 1
The Date is:
12 2 1
// use unsigned long if higher values
int number = 0;
void setup () {
delay(50);
Serial.println("Enter Date");
void loop () {
Date ();
void Date () {
int mm;
int m;
number = getnumber ();
mm = number;
Serial.print ("Month = ");
Serial.println (mm);
int dd;
dd = number;
Serial.print ("day = ");
Serial.println (dd);
int yy;
yy = number;
Serial.print ("Year = ");
Serial.println (yy);
PrintDate ();
void PrintDate () {
int mm;
int dd;
int yy;
Serial.println ("The Date is: ");
Serial.println(mm + '/' + dd + '/' + yy);
int getnumber (void) {
number = 0;
while (Serial.available () > 0 ) {
Serial.read ();
delay(50);
while (Serial.available () == 0) { }
while (Serial.available () > 0) {
byte ch = Serial.read ();
if (ch >= '0' && ch <= '9') {
number = (number * 10) + (ch - '0');
delay(5);
else {
Serial.println("Invalid");
return getnumber ();
return number;
try replacing all "println" with "print" and in your loop add Serial.println (""); after "Date()"
I want the Variable of mm,dd,yy go to
Serial.println (mm + dd + yy), is that possible and how?
You could make up a string, but it is easy to
Serial.print(day):
Serial.print(":");
Serial.print(month);
Serial.print(":");
Serial.println(year);
Im trying to set the time in the rtc. that’s why i need the variables mm, dd,yy to put it the "Serial.println (mm +dd+ yy) like that so i can check if code is correct…
The problem is that i cant set the time in the serial monitor.
Here’s the sample code.
Still dont know how to manipulate stored variables.
#include <DS3231.h>
DS3231 rtc(SDA, SCL);
int number = 0;
void setup () {
rtc.begin ();
delay(50);
void loop () {
if (Serial.available () > 0) {
int ch = Serial.read ();
Date ();
void showTime () {
Serial.print(rtc.getDOWStr());
Serial.print(" ");
Serial.print(rtc.getDateStr());
Serial.print(" -- ");
Serial.println(rtc.getTimeStr());
void Date () {
int mm;
int dd;
int yy;
mm = number;
dd = number;
Serial.print ("Day = ");
yy = number;
PrintDate ();
void PrintDate () {
int mm;
int dd;
int yy;
Serial.println ("The Date is Set to: ");
rtc.setDate(mm, dd, yy);
number = 0;
Serial.read ();
delay(50);
delay(5);
else {
showTime();
return number;
