SerialSoftware Problem
Hi guys, I am trying to do communication between two Arduino Mega by using SoftwareSerial but It doesn't work. Is there anyone to know that, what is the reason ?
Here is my transmitter code :
#include <SoftwareSerial.h>
SoftwareSerial active(50, 51);
SoftwareSerial passive(52, 53);
SoftwareSerial standby(10, 11);
// Transmitter
int Button1 = 13;
int Button2 = 12;
int Button3 = 7;
active.begin(9600);
passive.begin(9600);
standby.begin(9600);
pinMode(Button1, INPUT_PULLUP); // for read button
pinMode(Button2, INPUT_PULLUP); // for read button
pinMode(Button3, INPUT_PULLUP); // for read button
if (digitalRead(Button1) == 0)
active.write('1');
Serial.println("button 1 pressed");
if (digitalRead(Button2) == 0)
passive.write('2');
Serial.println("button 2 pressed");
if (digitalRead(Button3) == 0)
standby.write('3');
Serial.println("button 3 pressed");
delay(50); // waitting message send
And here is my receiver code :
//Reciever
int LED1 = 13;
int LED2 = 12;
int LED3 = 7;
char message1;
char message2;
char message3;
active.begin(9600);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
if (active.available())
message1 = active.read();
if (message1 == '1')
digitalWrite(LED1, HIGH);
if (passive.available())
message2 = passive.read();
if (message2 == '2')
digitalWrite(LED2, HIGH);
if (standby.available())
  message3 = standby.read();
  if (message3 == '3')
    digitalWrite(LED3, HIGH);
delay(20);
digitalWrite(LED1,LOW);
digitalWrite(LED2,LOW);
digitalWrite(LED3,LOW);
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
If you get errors when compiling please copy them from the IDE using the "Copy error messages" button and paste the clipboard here in code tags
So what does it do ?
What should it do ?
How are the 2 Arduino connected ?
Why are you using SoftwareSerial on Megas that have 4 hardware UARTS ?
Firstly, thank you for your answer. In real project I will have use Arduino UNO. Because of this I am using SerialSoftware now. I am trying to transfer data from one Arduino to another Arduino. When I use just 1 SoftwareSerial, I can do that. When I use more than 1, like in the code, it doesn't work. Do you know what is the reason?
See https://www.arduino.cc/en/Reference/SoftwareSerialListen
Read below.
https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html
Okay, thank you for your answer. As far as I can see, only 1 Software Serial can available at the same time. That's why my codes doesn't work. Thank you. I think I have to use hardware Serial.
Only certain pins on the Mega can be used for software serial. See the Software serial reference.
There is absolutely nonsense in use software serial when can use hardware serial. :roll_eyes:
