I came to the conclusion that IDE 1.57- 1.58 and SerialSoftware is not working correctly.
With as simple script that is perfectly working with IDE 1.06, received data is corrupted with IDE 1.5x, as far as I can see transmit is OK;
My test is simply to send and receive data at 38400 bps on RX (pin 4) and TX pin (14).
Is there already a solution for that issue?
Robert
Example (with IDE 1.06):
With IDE 1.06
Serial RX Goodnight moon!
Serial TX to mySerial RX AT+
mySerial TX to Serial RX ERROR(0)
Example (with IDE 1.5x):
With IDE 1.06
mySerial TX to Serial RX …MJLJ#.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(4, 14); // RX, TX
Serial.begin(57600);
Serial.println(“Goodnight moon!”);
// set the data rate for the SoftwareSerial port
mySerial.begin(38400);
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
