SerialTransfer between two Arduinos not working
I'm using the library SerialTransfer to send an integer between two arduino unos. The problem is that the receiver is receiveng the data, but it's displaying 0 everytime..
Here below there is my code:
TX
#include "SerialTransfer.h"
#include <SoftwareSerial.h>
SoftwareSerial s(3,2); //Rx, Tx
SerialTransfer myTransfer;
struct STRUCT {
  int num;
  //int negnum;
} testStruct;
int randnum;
  s.begin(9600);
  myTransfer.begin(s);
  randnum = 10 + random(1,15);
  testStruct.num = randnum;
  myTransfer.txObj(testStruct, sizeof(testStruct));
  myTransfer.sendData(sizeof(testStruct));
  Serial.print(testStruct.num); //Serial.println(testStruct.negnum);
RX
struct STRUCT {
  int num;
  //int negnum;
} testStruct;
  s.begin(9600);
    if(myTransfer.available()) {
      myTransfer.rxObj(testStruct, sizeof(testStruct));
      Serial.print("number positive: "); Serial.print(testStruct.num); //Serial.print("number negative: "); Serial.println(testStruct.negnum);
    else if(myTransfer.status <0) {
      Serial.print("ERROR");
      Serial.println(myTransfer.status);
Why is this happening? How can I fix this?
Have you connected
Arduino1 Arduino2
RX ------------> TX
TX ------------> RX
and both GND together ?
RV mineirin
I tried the code with 2 Unos and get the same results. I do not know how to fix the code. I use code based on the serial input basics tutorial. The methods are not hidden in a library in that tutorial code. I believe that the tutorial teaches the basics of serial comms better, but that's me.
Hi, try this sketchs.
Here it worked correctly;
RV mineirin
// Transmiter
SoftwareSerial s(3, 2); //Rx, Tx
struct STRUCT {
  int num;
} testStruct;
int randnum;
  s.begin(9600);
  randnum = 10 + random(1, 15);
  uint16_t sendSize = 0;
  sendSize = myTransfer.txObj(testStruct, sendSize);
  myTransfer.sendData(sendSize);
// Receiver
struct STRUCT {
  int num;
} testStruct;
  s.begin(9600);
    uint16_t recSize = 0;
    recSize = myTransfer.rxObj(testStruct, recSize);
    Serial.println(testStruct.num);
