This seems to work to reset the microcontroller, however there's a problem. The Arduino Due board is connected to a PC via the USB-to-serial interface. The PC is running MS-Windows version 10. When the microcontroller resets, I can hear MS-Windows make the "di dum" sound that it makes when a USB device is disconnected -- and this is how I can no longer communicate with the microcontroller.
I want to continue to communicate with the microcontroller via the USB-to-serial interface after I reset the microcontroller. How can I do this?
I can think of two possibilities here: Possibility 1: Stop the Arduino Due from reporting that it's turned off, and so MS-Windows won't make the "di dum" sound. Possiblity 2: After the "di dum" sound, execute code on the microcontroller that makes MS-Windows make the "dum dem" sound to indicate something has just connected.
It would be a lot handier just to power cycle the microcontroller, but the person who is testing it is a few thousand miles away and he is TeamViewer'ed into the Microsoft Windows PC that's connected to the microcontroller.
So instead of turning it off and back on, he's iissuing a command over RS232 to tell it to reset.
The solution will probably have to be on the PC side as when you reset the Arduino the pins tristate and the USB is no longer active. As it is programed to do the windows drops the connection and continues to search for a connection. I will take a SWAG and say you may be able to find an active USB adapter and/or isolator that may work.
Obviously, you want the C++ setup code to properly handle the USB reset so Windows will react just as if the cable was unplugged and plug in; that is Plug'nPlay needs to enumerate fully. If still problematic, you may need to use an output line to force the atmega16U2 reset pin low for a few hundredth milliseconds and then software reboot the Due.
