Series of indipendent relay
i need to use two indipendent relay activated from arduino pin 7 and pin 8 output. A single relay work well but when i put second relay all relay turn on and turn off at the same time.
Maybe my schema or my resistor is not adeguate
this is my schema :
i need to open relay on pin 7 separately to pin 8, thath occur is when pin 7 is open also pin8 is open and when pin 8 is open also 7 is open...
  Blink
  Turns an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
  it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
  the correct LED pin independent of which board is used.
  If you want to know what pin the on-board LED is connected to on your Arduino
  model, check the Technical Specs of your board at:
  https://www.arduino.cc/en/Main/Products
  modified 8 May 2014
  by Scott Fitzgerald
  modified 2 Sep 2016
  by Arturo Guadalupi
  modified 8 Sep 2016
  by Colby Newman
  This example code is in the public domain.
  https://www.arduino.cc/en/Tutorial/BuiltInExamples/Blink
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(7, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(7, LOW);   // turn the LED off by making the voltage LOW
  delay(2000);
  digitalWrite(8, HIGH);  // turn the LED on (HIGH is the voltage level)
  digitalWrite(8, LOW);                  // wait for a second
Looks like you’re just activating both relays successively in loop(). Where are your if() statements? What is your actual objective, in full? Is this a school project?
What's the current rating of the specific relay that you're using?
I don't need loop for now. Same things occours if i use only pin 7, both releay switch on and of.
Is that connection to -12V or 0V ?
Are the ground for the arduino and the ground for the 12V power supply connected together?
Yes -12v , and yes the ground of battery of 12v nd arduino ground in connected as in the schema.
Then please show the actual code that you are running.
And you didn’t answer my question about what activates each relay?
Nor the other questions!
Solve.
Soldering error.
Thanks to all
