server(80);
Hi
I am trying to make my Arduino visible on the internet. I have a Linksys router and have programmed a port forward from external to internet (external for example 123 pointet to internal 80) unfortunately nothing happens when I type my Ip-adress followed by :123 - nothing happens. If i test my ip-adress i get my NAS server, I think it is responding on port 80 (?)
How can I change Arduinos port to a different one 8090 for example? (I have tried the example code but then the Arduino does not show ip internal on its IP dress (192.168.1.64) The router is programmed to forward xx.xx.xx.xx:123 to 8090 - nothing happens.
kind regards
Karsten
Maybe the router firewall?
Depending on just where you are trying to access your gadget from, you may also find your ISP is the problem - many of them block things like port 80 from home networks to prevent people from setting up servers at home.
THX for your answers.
I am trying to get to my network by using my mobile.
If I only type the IP address I get my NAS server, my NAS is on port 80 :slight_smile:
If I add :123 or another port I get nothing.
/Karsten
#include <SPI.h>
#include <Ethernet.h>
#include <DHT11.h>
#include <RealTimeClockDS3231.h>
#define DHT11PIN_1 49
dht11 DHT11; //?? Sensor_2 needed?
int chk, Sensor_2;
// RTC_DS3231 rtc;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x19, 0x8D };
EthernetServer server(7575); //Works only if this is changed to 80 :-/
EthernetClient client;
const int numPins = 5;
int pins[] = {3, 4, 5, 12, 13};
int pinState[] = {0, 0, 0, 0, 0};
char line1[100];
char buffer[100];
char formatted[] = "00-00-00 00:00x";
