server and get time
im running a wemos D1 R1 and wondering if someone can point me towards guidance on how o run a server and get the time from a server. i’m planning on controlling lights on a time basis or sunset/sunrise basis but want the details and override on my phone so need a server. I’d appreciate some help pointing me to previous answers, ( if you’d like to know my skill level, it took me 20 mins to discover how to post !!!)
this is the server code I’m working/basing project on.
i think code was from Wemos webserver example - esp8266 learning
#include <ESP8266WiFi.h>
const char* ssid = "VM1923921";
const char* password = "fg3yvYqwgztn";
int ledPin1 = D4;
int ledPin2 = D11;
int ledPin3 = D12;
int ledPin4 = D13;
WiFiServer server(80);
  delay(10);
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  pinMode(ledPin4, OUTPUT);
  digitalWrite(ledPin1, HIGH);
  digitalWrite(ledPin2, HIGH);
  digitalWrite(ledPin3, HIGH);
  digitalWrite(ledPin4, HIGH);
  // Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.print("Use this URL : ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  // Read the first line of the request
  String request = client.readStringUntil('\r');
  Serial.println(request);
  client.flush();
  // Match the request
  int value1 = LOW;
  if (request.indexOf("/LED1=ON") != -1) {
    value1 = HIGH;
  if (request.indexOf("/LED1=OFF") != -1){
    digitalWrite(ledPin1, LOW);
    digitalWrite(ledPin3, LOW);
    digitalWrite(ledPin4, LOW);
    value1 = LOW;
    int value2 = LOW;
  if (request.indexOf("/LED2=ON") != -1) {
    value2 = HIGH;
  if (request.indexOf("/LED2=OFF") != -1){
    digitalWrite(ledPin2, LOW);
    value2 = LOW;
  // Return the response
  client.println("Content-Type: text/html");
  client.println(""); //  do not forget this one
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.println("<body><h1>hello world</h1></body>");
    client.println("<h2>-------------------------<\h2>");
  client.print("Led pin1 is now: ");
  if(value1 == HIGH) {
    client.print("On");
    client.print("Off");
  client.println("
  client.println("<h3>Click <a href=\"/LED1=ON\">here</a> turn the LED on pin 4 ON <\h3>
  client.println("Click <a href=\"/LED1=OFF\">here</a> turn the LED on pin 4 OFF
  client.println("</html>");
  client.println("
  client.println("Click <a href=\"/LED2=ON\">here</a> turn the LED2 on pin 11 ON
  client.println("Click <a href=\"/LED2=OFF\">here</a> turn the LED2 on pin 11  OFF
  delay(1);
  Serial.println("Client disconnected");
  Serial.println("");
If you want to update only one field on the page without reloading the entire page:
If you need to have the time count on the server:
If you want to have a more precise time, synchronized worldwide:
Here is a tutorial on getting NTP time on an ESP8266. (The Wemos is in the ESP family, so the code should run with no changes).
