Server Connection with X.509 Key from Trusted Authority
Using the MKR NB1500, I successfully followed the tutorial in this link:
https://create.arduino.cc/projecthub/Arduino_Genuino/securely-connecting-an-arduino-nb-1500-to-azure-iot-hub-af6470
The tutorial, however, uses a self-signed certificate to establish a connection to Microsoft Azure IoT hub. In my case, I would like to establish a connection generating my own X.509 certificate having certificate-authority. I was able to find a github repo on generating all of the required certificates, but the example code does not use the NBSSL class. That example can be found here:
To summarize, I want to establish a secure server connection with Arduino's NBSSL class using my own generated certificate-authority certificate. Thanks in advance.
Hi tkowalski887,
Did you get to any results? Happy to hear if you found a solution.
Cheers,
R.
