Servo 0 - 180 - 0
Hey,
I'm totally new to the Arduino experience and i would like to ask you guys if you could tell me where i could find some information for my project.
The project is simple :
1 - button push = servo goes from 0 to 180 degrees
2 - button push = servo goes back from 180 degrees to 0
I know that for you guys this is a project that can be done in two minutes but i can't find or don't (...yet) know how to find the information that i need.
i will be grateful for any information.
Best regards,
Bart
Start by looking through the example programs that come with the Arduino IDE. There are examples for button switches and for servos.
...R
Possible info:
https://www.google.com/search?ie=UTF-8&oe=UTF-8&q=servo+toggle&btnG=search&domains=http%3A%2F%2Fforum.arduino.cc&sitesearch=http%3A%2F%2Fforum.arduino.cc&gws_rd=ssl
There’s a servo example in the IDE Examples, wouldn’t be hard to have it move after reading a button push vs a reading fom analog input.
 Arduino Starter Kit example
 Project 5 - Servo Mood Indicator
 This sketch is written to accompany Project 5 in the
 Arduino Starter Kit
 Parts required:
 servo motor
 10 kilohm potentiometer
 2 100 uF electrolytic capacitors
 Created 13 September 2012
 by Scott Fitzgerald
 http://arduino.cc/starterKit
 This example code is part of the public domain
// include the servo library
#include <Servo.h>
Servo myServo; // create a servo object
int const potPin = A0; // analog pin used to connect the potentiometer
int potVal; // variable to read the value from the analog pin
int angle; // variable to hold the angle for the servo motor
 myServo.attach(9); // attaches the servo on pin 9 to the servo object
 Serial.begin(9600); // open a serial connection to your computer
 potVal = analogRead(potPin); // read the value of the potentiometer
 // print out the value to the serial monitor
 Serial.print("potVal: ");
 Serial.print(potVal);
 // scale the numbers from the pot
 angle = map(potVal, 0, 1023, 0, 179);
 // print out the angle for the servo motor
 Serial.print(", angle: ");
 Serial.println(angle);
 // set the servo position
 myServo.write(angle);
 // wait for the servo to get there
 delay(15);
Note that the "button push" is non-trivial - it requires de-bouncing and transition logic as presumably you do not want the servo to keep cycling if the button is held pushed.
Thank you all for your help :slight_smile:
