hello all i try to creat a code for this exemple but i dont have sucess can help de code i use is this
#include <Servo.h>
Servo myservo0;
//Set Pinouts->Sensors, buttons, LEDs
const byte btn0 = 5;
const byte endStopBottom0 = 9;
const byte endStopTop0 = 8;
boolean btn0ClickedUp = false;
boolean btn0ClickedDown = false;
int pos0 = 0;
int dir = 180;
int esq = 0;
PinoutConfig();
}//END void setup()
if(btn0ClickedUp && !endStopTop0){
myservo0.write(pos0);
delay(15);
else if(btn0ClickedDown && !endStopBottom0){
myservo0.write(dir);
delay(15);
//Serial.print("Servo0 position: ");
//Serial.println(pos0);
}//END void loop()
//Config
void PinoutConfig() {
myservo0.attach(10);
pinMode(btn0, INPUT);
//podes utilizar o INPUT_PULLUP nos pinos que tiverem
attachInterrupt(digitalPinToInterrupt(btn0), btn0Click, RISING); //FALLING or RISING depende se está em pull-up ou pull-down
pinMode(endStopBottom0, INPUT);
pinMode(endStopTop0, INPUT);
}//END void PinoutConfig()
//Buttons functions
void btn0Click() {
if(digitalRead(endStopBottom0)){
btn0ClickedUp = true;
else if(digitalRead(endStopTop0)){
btn0ClickedDown = true;
}//END btn0Click()
i dont have sucess
What happens when you run the code ?
How are the servos powered (I can't tell from the picture) ?
What state will the inputs be in when the buttons are not pressed and what will keep them in that state ?
the image is ilustrative for i wont to make but when i run the code nothing is happen
if (btn0ClickedUp && !endStopTop0)
What part of the code changes the value of btn0ClickedUp and endStopTop0 ?
this code is make a friend and i try to understand the code now i try this code
#include <Servo.h>
const byte pushbt = 5;
const byte switchend1 = 8;
const byte switchend2 = 9;
const byte servoPin = 10;
Servo servo;
byte pushbtstate = LOW;
byte end1state = LOW;
byte end2state = LOW;
byte Pos = 0;
byte esq =180; // new
byte dir = 0; // new
byte stop = 90;
pinMode(pushbt, INPUT);
pinMode(switchend1, INPUT_PULLUP);
pinMode(switchend2, INPUT_PULLUP);
servo.attach(servoPin);
void loop () {
readButtons();
moveServo();
moveStop1();
moveStop2();
void readButtons() {
pushbtstate = digitalRead(pushbt);
end1state = digitalRead(switchend1);
end2state = digitalRead(switchend2);
void moveServo() {
if (pushbtstate == LOW) {
if (Pos == esq) {
Pos = dir;
else {
Pos = esq;
pushbtstate = HIGH;
servo.write(Pos);
delay(200);
Serial.println(Pos);
void moveStop1() //pin8 top
if (end1state == LOW){
if (Pos == stop) {
Pos = stop;
else {
Pos = stop;
end1state = HIGH;
servo.write(stop);
void moveStop2() //pin9 buttom
if (end2state == LOW){
if (Pos == stop) {
Pos = stop;
else {
Pos = stop;
end2state = HIGH;
servo.write(stop);
