Servo advice needed
I need a servo to go beyond 180 degrees - but specifically not continuous.
I have a requirement that I need to be able to stop the servo at various points between 0 - 360
I could maybe get away with stopping at around 270-300 degrees.
Is there a servo that can do this? and if not, then what does everyone use instead of servos ?
There are plenty of "sail winch" servos. These typically have full positional control over 3 to 6 complete rotations. E.g. https://hobbyking.com/en_us/turnigytm-tgy-6114md-digital-sail-winch-servo-drum-type.html
I can't think of anything that does specifically 360 degrees but they may exist...it's basically a matter of the way the gearing is arranged. But finding them is difficult because as you've seen people use "360 degree" to mean continuous rotation (which isn't really a servo at all, just a geared motor).
Steve
Welcome to the forum.
What is the application that you need 360deg turn?
Thanks.. Tom.. :slight_smile:
Most servos will do 270 deg - same as the travel of a potentiometer....
hammy:
Are you sure? I have dozens of servos and quite a few of them can't even manage 180 degrees.
Steve
TomGeorge:
I'm making a gauge for my flight sim... basically trying to build this:
Yep sure , I’ve some that do . You need the range of PWM signals to drive it this far .
There maybe an internal stop , ( which you can modify) but travel is ultimately limited by the travel of the feedback pot.
Ok great.. so what do I need to do ?
