Servo and DC motor
Hello, i'm very new on Arduino world but i have some experience of programming in other language.
i'm try to make my first robot car, i have 2 DC motor connect to a module L298N , all connected to a 9V battery and arduino uno.
DC motor connected to port 5,6,7 for the motor 1 and port 8,9,10 for motor 2
the code working fine to go forward and back.
At this stage I want to connect a dc servo , which i connected to the port 13, to the 5 volt and to ground, now here the issue ..
with the following code only one DC motor and servo moving but the second DC motor is stuck!
i notice that if i remove from the void setup the command "servo_motor.attach(13);" both dc motor running.
it should move servo and both DC motor...
any reason why?
thanks for help
Dm1886
#include <Arduino.h>
#include <Servo.h>
const int mot2 = 10;
const int ava2 = 9;
const int ind2 = 8;
const int mot1 = 5;
const int ava1 = 6;
const int ind1 = 7;
Servo servo_motor;  // create servo object to control a servo
int pos = 0;
 void moveForward()
 Serial.print("Going Forward\n");
  // turn on motor A
  digitalWrite(ava1, HIGH);
  digitalWrite(ind1, LOW);
  // set speed to 200 out of possible range 0~255
  analogWrite(mot1, 100);
  // turn on motor B
  digitalWrite(ava2, LOW);
  digitalWrite(ind2, HIGH);
  analogWrite(mot2, 100);
  delay(2000);
void moveBack()
 Serial.print("Going BACK\n");
  // turn on motor A
  digitalWrite(ava1, LOW);
  digitalWrite(ind1, HIGH);
  analogWrite(mot1, 250);
  // turn on motor B
  digitalWrite(ava2, HIGH);
  digitalWrite(ind2, LOW);
  analogWrite(mot2, 250);
  delay(2000);
void moveServo(){
 for (pos = 0; pos <= 180; pos += 1) {
    servo_motor.write(pos);
    delay(15);
  for (pos = 180; pos >= 0; pos -= 1) {
    delay(15);
  servo_motor.attach(13); //  why if i remove this both DC motor work and if i put only one DC motor work??
  pinMode(mot2, OUTPUT);
  pinMode(ava2, OUTPUT);
  pinMode(ind2, OUTPUT);
  pinMode(mot1, OUTPUT);
  pinMode(ava1, OUTPUT);
  pinMode(ind1, OUTPUT);
moveServo();
delay(2000);
moveForward();
delay(2000);
moveBack();
How is the Arduino powered? A schematic of all connections would help.
Probably you don't have enough power to run motors and a servo. If "9V battery" is a little rectangular smoke-detector battery and that's the only power you have then you definitely don't have enough power to run motors and a servo.
Steve
What is the power source for the motors and servo.
If the battery is what I know as a PP3 then it will not last long
As to the motor control problem, have a look at Servo - Arduino Reference which, amongst other things says
On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins.
Guess which pin you are using for mot2
Yes, it look like a limitation of the library, on arduino uno... i have try in on arduino mega and it work perfect with the 9 volt battery....
the strange stuff is .. i have try to move the dc motor to the pin 2,3,4,5,6,7 and servo connect on 8.. use it on arduino uno... and still not working....
on mega all perfect...
#include <Servo.h>
const int mot2 = 2;
const int ava2 = 3;
const int ind2 = 4;
const int mot1 = 5;
const int ava1 = 6;
const int ind1 = 7;
int pos = 0;
 void moveForward()
  // turn on motor A
  // turn on motor B
  delay(2000);
void moveBack()
  // turn on motor A
  // turn on motor B
  delay(2000);
void moveServo(){
    delay(15);
    delay(15);
  servo_motor.attach(8); // <<<<<<<<<
delay(4000);
moveServo();
delay(2500);
moveForward();
delay(2500);
moveBack();
delay(4000);
Pin 2.is not a PWM pin.
The Servo library uses one of the hardware timers. That timer can't also be used for PWM.
That is why Motor 2 isn't working right. Try a different PWM pins for Motor 2.
