Hi folks! I'm quite new to arduino. I'm working on project with distance measurements and servos. I may say something like sonar. I have problem to send data from servo (its position) and distance from ultrasonic sensor to processing.
**This is my arduino code:**include <Servo.h>
const int trigPin = 42;
const int echoPin = 43;
Servo myservo;
Servo myservo1;
int pos = 0;
myservo.attach(10);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
long duration, cm;
for(pos = 5; pos < 180; pos += 1)
myservo.write(pos);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
Serial.print("@");
Serial.print(cm);
Serial.print("");
Serial.print(pos);
delay(50);
cm = microsecondsToCentimeters(duration);
for(pos = 180; pos>=10; pos-=1) // goes from 180 degrees to 0 degrees
myservo.write(pos);
Serial.print("@");
Serial.print(cm);
Serial.print("");
Serial.print(pos);
delay(50);
long microsecondsToCentimeters(long microseconds)
return microseconds / 29 / 2;
And this is processing code:
import processing.serial.*;
int linefeed = 10; // linefeed in ASCII
int carriageReturn = 13; // carriage return in ASCII
Serial myPort; // The serial port
int sensorValue = 0; // the value from the sensor
float pos = 0;
float cm = 0;
println(Serial.list());
myPort = new Serial(this, Serial.list()[0], 9600);
myPort.bufferUntil(carriageReturn);
void draw() {
void serialEvent(Serial myPort) {
String myString = myPort.readStringUntil(linefeed);
if (myString != null) {
parseString(myString);
void parseString(String serialString) {
String items[] = (split(serialString, '*'));
if (items[0].equals("@") == true) {
pos = float(items[1]);
cm = float(items[3]);
println(pos + "," +cm);
