Servo and Motor Driver incompatibility
Dear Forum, I have been using an Arduino Uno and a Critical Velocity 15 Amp Bidirectional PWM Motor Speed Controller to control a 12V 10 AMP motor. Things have been running perfectly until I added a SparkFun Large Servo to the Arduino. Now the motor will not run in reverse. SparkFun suggests a separate power supply for the servo or noise filtering. I have a robust 12V power supply for the Motor Controller. Rather not add another 5V supply for the servo. Any suggestions on how to add the servo without throwing a wrench in to the soup? Greatly appreciated.
This sounds like a code problem. Did you include the Servo library in your code? On a non-Mega Arduino that will disable PWM on pins 9 and 10.
Well, direct 12v to the servo may kill it, and the arduino is usually inadequate to power a servo itself. You might power the servo via a 7805 regulator chip connected to the 12v power supply.
zoomkat: You might power the servo via a 7805 regulator chip connected to the 12v power supply.
As they might say on 9gag... "You make a suggestion like that on this forum and you gonna have a bad time" 8)
JimboZA:
Not sure why. I've had a pair of web cam pan/tilt servos powered like below 24/7 since 2004 without any issues.
Chagrin: This sounds like a code problem. Did you include the Servo library in your code? On a non-Mega Arduino that will disable PWM on pins 9 and 10.
I believe I have cleared the code. Sketch runs fine with servo control lead disconnected. I did include the library in the code. I also ran a sketch with only the servo code and that runs fine.
JimboZA:
Could you elaborate on that please?
Some members are "against" regulators like that because they waste power.
In a 7805 style regulator, the input current is always the same as the output current, so since it's at a higher voltage, the difference in input - output voltage, times the current, is the wasted power in watts.
That waste manifests as heat.....
JimboZA: Some members are "against" regulators like that because they waste power.
Thank you JimboZA. Would you agree that it is a power problem and not a noise problem ? Do you have a alternate recommendation from the 7805 regulator? Thanks again for your assistance.
