Servo and Radiohead RH_ASK Libraries
Hi
Please can someone help?
I want to send servo positions from one pro mini (the controller) to another (the actuator) but am having compile error. I suspect the libraries are incompatible or use the same variables or timer.
can anyone suggest a workaround?
Error details:
In file included from C:\Users\user\Google Drive\Arduino\libraries\RadioHead/RHGenericDriver.h:9:0,
from C:\Users\user\Google Drive\Arduino\libraries\RadioHead/RH_ASK.h:9,
from C:\Users\user\Google Drive\Arduino\askradioheadtrial\askradioheadtrial.ino:2:
C:\Users\user\Google Drive\Arduino\libraries\RadioHead/RadioHead.h:305:51: warning: "/*" within comment [-Wcomment]
cp /usr/local/projects/arduino/libraries/RadioHead/*.h .
C:\Users\user\Google Drive\Arduino\libraries\RadioHead/RadioHead.h:306:51: warning: "/*" within comment [-Wcomment]
cp /usr/local/projects/arduino/libraries/RadioHead/*.cpp .
C:\Users\user\Google Drive\Arduino\askradioheadtrial\askradioheadtrial.ino: In function 'void loop()':
C:\Users\user\Google Drive\Arduino\askradioheadtrial\askradioheadtrial.ino:25:9: warning: unused variable 'i' [-Wunused-variable]
int i;
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function `ServoCount':
(.text+0x0): multiple definition of `__vector_11'
libraries\RadioHead\RH_ASK.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Pro or Pro Mini.
the code is:
//receiver
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
RH_ASK driver(2000, 11, 12, 0); // speed 2000, rx-pin 11 , tx-pin 12
  Serial.begin(9600); // Debugging only
  myservo.attach(9);
  if (!driver.init()) { //for receiver driver
    Serial.println("init failed");
    Serial.println("RX Ready");
  myservo.write(111); // just to ensure servo is complied
  uint8_t buf[10];
  uint8_t buflen = sizeof(buf);
  if (driver.recv(buf, &buflen)) {// Non-blocking
    int i;
    // Message with a good checksum received, dump it.
    //Serial.println("");
    Serial.print("Message: ");
    //Serial.println(buf);
    Serial.println((char*)buf);
    digitalWrite(13, 1);//flash led if received
    delay(10);
    digitalWrite(13, 0);
I'm trying to remote control 3 servos by continually sending packets of 3 servo angles 0-180.
I'm also having issues with replacing "hello" with a numeric variable (int or uint8_t) in the Radiohead ask example below.
const char *msg = "hello";
    driver.send((uint8_t *)msg, strlen(msg));
    driver.waitPacketSent();
For completeness the full example code is below. I have swapped line RH_ASK driver; for RH_ASK driver(2000, 4, 5, 0) where 2000 is TX rate, 4 is TXpin, 5 is RXpin 0 is PTT pin (unused) :
// ask_transmitter.pde
// -*- mode: C++ -*-
// Simple example of how to use RadioHead to transmit messages
// with a simple ASK transmitter in a very simple way.
// Implements a simplex (one-way) transmitter with an TX-C1 module
// Tested on Arduino Mega, Duemilanova, Uno, Due, Teensy, ESP-12
#include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
RH_ASK driver;
// RH_ASK driver(2000, 4, 5, 0); // ESP8266 or ESP32: do not use pin 11 or 2
    if (!driver.init())
    delay(200);
and the RX arduino example code is
// ask_receiver.pde
// Simple example of how to use RadioHead to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
#include <RH_ASK.h>
RH_ASK driver;
    if (!driver.init())
    uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
    if (driver.recv(buf, &buflen)) // Non-blocking
 int i;
 driver.printBuffer("Got:", buf, buflen);
Yep the latter, Servo.h uses all 16-bit timers and is therefore incompatible with any library that uses one of them (and that is quite often the case)
It is not to difficult to send a pulse to a servo using another method, (basically set the pin high, wait between 544us & 2400us and set the pin low again and do not repeat this pulse for at least 20ms) If you are using timers to control this process be aware that interrupts need to be turned on all the time for it to work, otherwise you could use a blocking method to achieve your goal.
Use the Servo Timer2 library instead.
Thank you to both Deva_Rishi and jremington.
Your help has saved me a lot of time and heartache :slight_smile:
Steve
