system
October 4, 2012, 9:43pm
#1
hi, ? will make robot using servo and ultrasonic sensor. then I had write a simple code using servo with sensor.
I want from program if distance under 5 cm servo turning 90 degree. please help me.thank you
where I do wrong?
#define trigPin 12
#define echoPin 13
#include <Servo.h>
Servo myservo;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
myservo.attach(9);
int duration, distance,pos=0;
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance<=5){
myservo.write(90);
delay(100);
else {
Serial.print(distance);
Serial.println(" cm");
Moderator edit: Code tags.
I think the default servo position is 90-degrees so moving it to 90-degrees won't do anything.
Is there a different position you'd like the servo to go to when the distance is > 5?
Denbo
October 5, 2012, 2:01am
#3
If you are using the HC-SR04 the 1000 microsecond delay is a bit long.
The specification doc says it should 10 microseconds (delayMicroseconds(10)).
Here is the doc:
http://jaktek.com/wp-content/uploads/2011/12/HC-SR04.pdf
Also you should specifically hold the trigger line LOW first for a little bit of time before setting it HIGH (just like the PING sensor).
Try the following code:
delayMicroseconds(2);
delayMicroseconds(10);
system
October 5, 2012, 8:15am
#4
Uncompiled, untested
#define trigPin 12
#define echoPin 13
#define servoPin 9
#define DEFAULT_SERVO_POS 0
#define TRIGGERED_SERVO_POS 90
#include <Servo.h>
Servo myservo;
myservo.write(DEFAULT_SERVO_POS);
myservo.attach(servoPin);
long duration = pulseIn(echoPin, HIGH);
long distance = (duration/2) / 29.1;
if (distance<=5){
myservo.write(TRIGGERED_SERVO_POS);
system
October 5, 2012, 11:56pm
#5
thank you for helping me.
? will use this code
#define trigPin 12
#define echoPin 13
#include <Servo.h>
Servo myservo;
void setup () {
Serial .begin (9600);
myservo.attach(9);
void loop () {
int duration, distance,pos=0,i;
Serial .print(distance);
Serial .println(" cm");
if(distance<5)
myservo.write(180);
else{
myservo.write(0);
delay(100);
