The servos jump around if I use my code or use yours. That is because if servo1 is completed its position movement and servo2 is still going they will both stop wait for the delay and then jump to the next position. This way servo1 will go to the next movement smoothly while servo2 has to jump and not be smooth. Example when servo1 goes from 80 to 100 and servo2 goes from 80 to 140 during the same time frame I see servo1 completing the movement from 80 to 100 quicker than servo2 which has a longer run. But once servo1 has completed its movement the program stops and waits for the delay and goes to the next position. Then Servo1 goes from 100 to 120 while servo2 has to jump to 140 which it hadn't completed and go to position 160. Look at the serial monitor after my code to see what I am talking about
#include <Servo.h>
Servo myservo1;
Servo myservo2;
const int pos1[] = {0, 40, 80, 100, [b]80, 100[/b], 120, 180, 100, 50, 0};
const int pos2[] = {0, 20, 80, 100, [b]80, 140[/b], 160, 100, 50, 20, 0};
const int turn_size = sizeof(pos1) / sizeof(pos1[0]);
const int delay1[turn_size] = {3000, 3000, 3000, 3000, 3000, 3000, 3000, 3000, 3000, 3000, 3000};
myservo1.attach(9);
myservo2.attach(4);
for (int i = 0; i < turn_size-1; i++)
//---start1
int start1 = pos1[i];
int end1 = pos1[i+1];
int start2 = pos2[i];
int end2 = pos2[i+1];
int inc1 = 1; // assume counting up
int inc2 = 1;
if ( end1 < start1 && end2 < start2)
inc1 = -1; // counting down
inc2 = -1;
else if ( end1 < start1 && end2 > start2)
inc2 = 1;
else if ( end1 > start1 && end2 < start2)
inc1 = 1; // counting down
inc2 = -1;
while( start1 != end1 && start2 != end2)
myservo1.write(start1);
delay(15);
start1 += inc1;
myservo2.write(start2);
delay(15);
start2 += inc2;
Serial.print("S1:");
Serial.print(start1);
Serial.print(", S2:");
Serial.println(start2);
delay(delay1[i]);
//---end1
Serial Monitor
16:13:44.803 -> S1:1, S2:1
16:13:44.803 -> S1:2, S2:2
16:13:44.844 -> S1:3, S2:3
16:13:44.844 -> S1:4, S2:4
16:13:44.877 -> S1:5, S2:5
16:13:44.913 -> S1:6, S2:6
16:13:44.947 -> S1:7, S2:7
16:13:44.982 -> S1:8, S2:8
16:13:45.020 -> S1:9, S2:9
16:13:45.054 -> S1:10, S2:10
16:13:45.091 -> S1:11, S2:11
16:13:45.091 -> S1:12, S2:12
16:13:45.127 -> S1:13, S2:13
16:13:45.162 -> S1:14, S2:14
16:13:45.196 -> S1:15, S2:15
16:13:45.232 -> S1:16, S2:16
16:13:45.266 -> S1:17, S2:17
16:13:45.299 -> S1:18, S2:18
16:13:45.299 -> S1:19, S2:19
16:13:45.336 -> S1:20, S2:20
16:13:48.385 -> S1:41, S2:21
16:13:48.419 -> S1:42, S2:22
16:13:48.419 -> S1:43, S2:23
16:13:48.453 -> S1:44, S2:24
16:13:48.486 -> S1:45, S2:25
16:13:48.520 -> S1:46, S2:26
16:13:48.554 -> S1:47, S2:27
16:13:48.588 -> S1:48, S2:28
16:13:48.625 -> S1:49, S2:29
16:13:48.658 -> S1:50, S2:30
16:13:48.695 -> S1:51, S2:31
16:13:48.695 -> S1:52, S2:32
16:13:48.730 -> S1:53, S2:33
16:13:48.766 -> S1:54, S2:34
16:13:48.802 -> S1:55, S2:35
16:13:48.836 -> S1:56, S2:36
16:13:48.871 -> S1:57, S2:37
16:13:48.908 -> S1:58, S2:38
16:13:48.908 -> S1:59, S2:39
16:13:48.945 -> S1:60, S2:40
16:13:48.978 -> S1:61, S2:41
16:13:49.015 -> S1:62, S2:42
16:13:49.048 -> S1:63, S2:43
16:13:49.082 -> S1:64, S2:44
16:13:49.118 -> S1:65, S2:45
16:13:49.155 -> S1:66, S2:46
16:13:49.155 -> S1:67, S2:47
16:13:49.188 -> S1:68, S2:48
16:13:49.222 -> S1:69, S2:49
16:13:49.257 -> S1:70, S2:50
16:13:49.295 -> S1:71, S2:51
16:13:49.330 -> S1:72, S2:52
16:13:49.330 -> S1:73, S2:53
16:13:49.368 -> S1:74, S2:54
16:13:49.402 -> S1:75, S2:55
16:13:49.436 -> S1:76, S2:56
16:13:49.472 -> S1:77, S2:57
16:13:49.506 -> S1:78, S2:58
16:13:49.539 -> S1:79, S2:59
16:13:49.574 -> S1:80, S2:60
16:13:52.591 -> S1:81, S2:81
16:13:52.625 -> S1:82, S2:82
16:13:52.662 -> S1:83, S2:83
16:13:52.697 -> S1:84, S2:84
16:13:52.697 -> S1:85, S2:85
16:13:52.732 -> S1:86, S2:86
16:13:52.766 -> S1:87, S2:87
16:13:52.802 -> S1:88, S2:88
16:13:52.837 -> S1:89, S2:89
16:13:52.875 -> S1:90, S2:90
16:13:52.909 -> S1:91, S2:91
16:13:52.909 -> S1:92, S2:92
16:13:52.946 -> S1:93, S2:93
16:13:52.984 -> S1:94, S2:94
16:13:53.017 -> S1:95, S2:95
16:13:53.055 -> S1:96, S2:96
16:13:53.093 -> S1:97, S2:97
16:13:53.093 -> S1:98, S2:98
16:13:53.128 -> S1:99, S2:99
16:13:53.170 -> S1:100, S2:100
16:13:56.196 -> S1:99, S2:99
16:13:56.230 -> S1:98, S2:98
16:13:56.264 -> S1:97, S2:97
16:13:56.303 -> S1:96, S2:96
16:13:56.303 -> S1:95, S2:95
16:13:56.337 -> S1:94, S2:94
16:13:56.370 -> S1:93, S2:93
16:13:56.404 -> S1:92, S2:92
16:13:56.437 -> S1:91, S2:91
16:13:56.470 -> S1:90, S2:90
16:13:56.504 -> S1:89, S2:89
16:13:56.538 -> S1:88, S2:88
16:13:56.575 -> S1:87, S2:87
16:13:56.575 -> S1:86, S2:86
16:13:56.613 -> S1:85, S2:85
16:13:56.648 -> S1:84, S2:84
16:13:56.685 -> S1:83, S2:83
16:13:56.722 -> S1:82, S2:82
16:13:56.757 -> S1:81, S2:81
16:13:56.790 -> S1:80, S2:80
16:13:59.815 -> S1:81, S2:81
16:13:59.849 -> S1:82, S2:82
16:13:59.849 -> S1:83, S2:83
16:13:59.885 -> S1:84, S2:84
16:13:59.920 -> S1:85, S2:85
16:13:59.953 -> S1:86, S2:86
16:13:59.990 -> S1:87, S2:87
16:14:00.023 -> S1:88, S2:88
16:14:00.056 -> S1:89, S2:89
16:14:00.090 -> S1:90, S2:90
16:14:00.124 -> S1:91, S2:91
16:14:00.124 -> S1:92, S2:92
16:14:00.157 -> S1:93, S2:93
16:14:00.190 -> S1:94, S2:94
16:14:00.224 -> S1:95, S2:95
16:14:00.262 -> S1:96, S2:96
16:14:00.298 -> S1:97, S2:97
16:14:00.331 -> S1:98, S2:98
16:14:00.368 -> S1:99, S2:99
[b]16:14:00.368 -> S1:100, S2:100
16:14:03.395 -> S1:101, S2:141[/b]
16:14:03.429 -> S1:102, S2:142
16:14:03.462 -> S1:103, S2:143
16:14:03.498 -> S1:104, S2:144
16:14:03.532 -> S1:105, S2:145
16:14:03.565 -> S1:106, S2:146
16:14:03.598 -> S1:107, S2:147
16:14:03.635 -> S1:108, S2:148
16:14:03.668 -> S1:109, S2:149
16:14:03.668 -> S1:110, S2:150
16:14:03.704 -> S1:111, S2:151
16:14:03.742 -> S1:112, S2:152
16:14:03.779 -> S1:113, S2:153
16:14:03.815 -> S1:114, S2:154
16:14:03.848 -> S1:115, S2:155
16:14:03.882 -> S1:116, S2:156
16:14:03.882 -> S1:117, S2:157
16:14:03.916 -> S1:118, S2:158
16:14:03.949 -> S1:119, S2:159
16:14:03.985 -> S1:120, S2:160
