Hi Guys
So first off: This code you see is a merge of the original Arduino Example Codes in Arduino IDE Called
- Servo → Sweep.ino
- Sensors → Ping.ino
So it’s very unlikely there’s something wrong with the code.
The Code itself does work seperately. Meaning:
If i just call the Ping() function, it works as it should (Ping and print values)
The Servo function without the Ping does work as well, and swipes 180° and back clean.
The problem comes when i mix them both together. The servo jumps a moves a few degrees, pings every time it moves, but then suddenly stops and does nothing for a few seconds.
It’s like the for-loop “freezes” for 2-3 seconds before it’s 180 degrees. Then it continues at the same point it stopped (so it does not reset to zero) and goes on a few intervals, until it freezes again.
Eventually it gets to 180 degrees and starts turning back, but wiht random freezes all the time.
The Servo, as well as The Ping-Sensor are connected to the 5v Output of the Arduino. Is that a problem?
If yes, how does a Parallax Boebot work with 3 Servos and a Ping Sensor directly connected to Arduino 5V output?
#include <Servo.h>
Servo sweep;
int pos = 0;
int increment = 1;
const int pingPin = 7;
long duration, cm;
sweep.attach(6);
void loop(){
for(pos = 0; pos <= 180; pos += 10)
ping();
sweep.write(pos);
delay(55);
for(pos = 180; pos>=0; pos-=10)
ping();
sweep.write(pos);
delay(55);
void ping(){
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
Serial.print(cm);
Serial.print("cm");
delay (20);
long microsecondsToCentimeters(long microseconds)
return microseconds / 29 / 2;
I commented both For-Loops and and just wrote ping(); in the main loop - ping works Ok.
Then i did the opposite: Commented both Ping() in the For-Loops and it swiped OK.
It is the interaction of both functions that causes the problem.
Any ideas anyone?
