Im getting only sound from my servo. In intervalls according to what i set in my code.
Could it be a voltage problem? if i mesaure voltage on the servo its between 3.8-4 v. How would i set up if i want it to run on 6v from 4 1.5v AA batterys? (guessing red-black to battery and leave only pin wire from the arduino board) tnx!
How could i change the code to try different update rates? like 50hz
Servo update is 50Hz, IIRC.
Same thing with extra power. Now pins on servo shows 5v
I don't understand that
Can you confirm that the servo, the battery, and the Arduino share a common ground, and that you have your Arduino's signal pin connected to the servo's signal wire.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(8); // attaches the servo on pin 9 to the servo object
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(25); // waits 15ms for the servo to reach the position
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
Can't see your wires to well in the picture, but just to confirm, servo ground, battery ground and Arduino ground all need to be connected together - can't tell from the pic.
Basic servo/arduino wiring setup and servo test code.
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7); //the pin for the servo control
Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
readString=""; //empty for next input
What type of servo do you have? Note that hand turning smaller servos might damage the gears if not careful. Also the small servos like the 9g ones may strip gears if run against the internal hard stop when at near max voltage.
I seem to be the only person on the planet that this happens to, but I often need to connect a 1K or 10K resistor in the signal line to the Servo or my projects hang.
Like I say no one else seems to have this problem but maybe I just use a wider variety of servos.
