I have messured a peak voltage of 5V if I use a very easy sketch using PWM. Without xboxcontroller.
For the Controller I`ve downloaded Revision 2.0 of USB_Host_Shield_20 from Github.com .
So, there is the issue.
When i run the init(), there is only a paek volatge of 2.5V ! In the attachment you can find code fragments..
For our Servo, Hitec HS-645MG, we need the higher peak.
The question now is, how we solve this and how we get the 5V peak, because without init(), the controller wont start.
Frequency: 490 Hz
Duty Cycle: between 0 and 255 is the analog Write Function, our Servo works between 70 and 170.
In the attachement is a picture of the oscilloscope. We use Pin 9 for Servo 1 (Yellow line), it only reaches 2.5 V.
The Blue Line on Pin 11 has the correct 5 V.
