hey, I need a little help in programing, I have two servo facing eachother, when I use the normal arduino code given in examples, I get both servo running perfectly but in opposite direction, instead I want both servos to run in same direction while facing each other so it would be like when one servo going from 0 to 45 degree the other should go from 45 to 0 degree, so here is the code I used.
#include <Servo.h>
int relay2 = 2;
Servo servo8;
int relay3 = 3;
Servo servo9;
int pos = 0; // variable to store the servo position
pinMode(relay2, OUTPUT);
servo8.attach(8);
pinMode(relay3, OUTPUT);
servo9.attach(9);
digitalWrite(relay2, HIGH);
digitalWrite(relay3, HIGH);
for(pos = 0; pos < 45; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
servo8.write(pos); // tell servo to go to position in variable 'pos'
servo9.write(pos);
delay(15); // waits 15ms for the servo to reach the position
for(pos = 45; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
servo9.write(pos);
digitalWrite(relay2, LOW);
digitalWrite(relay3, LOW);
currently these both servo are set in same motion as you can see in the code, but I want them to go opposite simulateously at the same time just like I said before. I tried different techniques, but nothing seems to be work because I am at very basic level and one more important thing that I am using this code because I want to control the timing.
thanks
