Hi I am a bit baffled with the servo consistency. I damaged a few servos because I over-shot the range.
I use MG996R servo. These servos to begin with do not have the best quality. I found this code awhile ago:
in the hope that I can map the range to as close to a full 180 degrees sweep.
Is this the correct apporach to adjust the servos so that they won't crash? Thanks.
Thanks.. Tom...
There isn't much to draw. Basically, I use a 16-channel board to drive each servo. The board itself I use the 5v Arduino power. for the servos I use an external power supply, in order to give the servos higher torque. I gave the servos 6-7v. I read that the MG996R can tolerate as much as 7v. When I use the above code. some of the servos can reach very close to 180. But few of them only reach up to about 160.
That code will not even compile, you have to post all your code for it to make any sense. Please read the how to use this forum sticky post, it will tell you how to ask a question.
Yes there is, but if you don’t want help this is the right way to go about not getting any.
