I am making my own coil metal detector and have made the serial monitor say Metal detected if it detects metal and no metal if not. I want to make a servo motor turn when it says metal detected and for that the servo has to read the serial monitor to see when it says metal detected. I want to make an if statement basically saying if the serial monitor says metal detected turn the servo 90 degrees. How do I do that? I am new to programming and would appreciate if you could help me.
#include <Servo.h>
Servo myServo;
int servoPin=9;
int servoPos=180;
const byte npulse = 12; // number of pulses to charge the capacitor before each measurement
const byte pin_pulse = A0; // sends pulses to charge the capacitor (can be a digital pin)
const byte pin_cap = A1; // measures the capacitor charge
const byte pin_LED = 12; // LED that turns on when metal is detected
myServo.attach(servoPin);
pinMode(pin_pulse, OUTPUT);
digitalWrite(pin_pulse, LOW);
pinMode(pin_cap, INPUT);
pinMode(pin_LED, OUTPUT);
digitalWrite(pin_LED, LOW);
const int nmeas = 256; //measurements to take
long int sumsum = 0; //running sum of 64 sums
long int skip = 0; //number of skipped sums
long int diff = 0; //difference between sum and avgsum
long int flash_period = 0; //period (in ms)
long unsigned int prev_flash = 0; //time stamp of previous flash
int minval = 2000;
int maxval = 0;
//perform measurement
long unsigned int sum = 0;
for (int imeas = 0; imeas < nmeas + 2; imeas++) {
//reset the capacitor
pinMode(pin_cap, OUTPUT);
digitalWrite(pin_cap, LOW);
delayMicroseconds(20);
//apply pulses
for (int ipulse = 0; ipulse < npulse; ipulse++) {
digitalWrite(pin_pulse, HIGH); //takes 3.5 microseconds
delayMicroseconds(3);
digitalWrite(pin_pulse, LOW); //takes 3.5 microseconds
//read the charge on the capacitor
int val = analogRead(pin_cap); //takes 13x8=104 microseconds
minval = min(val, minval);
maxval = max(val, maxval);
sum += val;
//determine if LEDs should be on or off
long unsigned int timestamp = millis();
byte ledstat = 0;
if (timestamp < prev_flash +12) {
if (diff > 0)ledstat = 1;
if (diff < 0)ledstat = 2;
if (timestamp > prev_flash + flash_period) {
prev_flash = timestamp;
if (flash_period > 1000)ledstat = 0;
//switch the LEDs to this setting
if (ledstat == 0) {
Serial.println("No metal");
if (ledstat == 1) {
if (ledstat == 2) {
digitalWrite(pin_LED, HIGH);
Serial.println("Metal detected");
if Serial.print=("Metal detected")
myServo.write(servoPos);
//subtract minimum and maximum value to remove spikes
sum -= minval; sum -= maxval;
//process
if (sumsum == 0) sumsum = sum << 6; //set sumsum to expected value
long int avgsum = (sumsum + 32) >> 6;
diff = sum - avgsum;
if (abs(diff)<avgsum >> 10) { //adjust for small changes
sumsum = sumsum + sum - avgsum;
skip = 0;
skip++;
if (skip > 64) { // break off in case of prolonged skipping
sumsum = sum << 6;
skip = 0;
// one permille change = 2 ticks/s
if (diff == 0) flash_period = 1000000;
else flash_period = avgsum / (2 * abs(diff));
When I changed a part of the code to this
if (ledstat == 2) {
myServo.write(90);
delay(3000);
myServo.write(0);
It just says Metal detected forever and the led stays on and doesn't turn off and says No metal.
How do I fix this???
