Servo control - from Processing?
Hello everyone,
Ok so I’ve been working all day but to no avail…
I’m attempting to control a servo motor via serial communication (characters sent from a simple Processing sketch)
Since I’ve never done this before I tried to use the LED example (that detects if the mouse cursor is over the square and if so, send power to the LED) as a starting point.
I assumed that it would be as easy as changing the code to send a pulse to the servo as the serial reads a ASCI character, but I’m getting no movement.
The other problems occur when I attempt to run the Processing sketch - it sometimes disconnects the serial connection leaving error messages etc.
heres the code for the ARDUINO:
int outputPin = 13;
int val;
int minPulse = 1000;
int maxPulse = 2500;
int pulse = 0;
int lastPulse = 0;
int refreshTime = 20;
  pinMode(outputPin, OUTPUT);
  pulse = maxPulse;
  Serial.begin (9600);
  if (Serial.available()) {
    val = Serial.read();
    if (val == 'H') {
      pulse = minPulse;
    if (val == 'L') {
      pulse = maxPulse;
 updateServo();
void updateServo()
   if (millis() - lastPulse >= refreshTime) {
    digitalWrite(outputPin, HIGH);
    delayMicroseconds(pulse);
    digitalWrite(outputPin, LOW);
    lastPulse = millis();
heres the code for PROCESSING
import processing.serial.*;
Serial port;
  size (200,200);
  noStroke();
  frameRate(10);
  println(Serial.list());
  port = new Serial(this, Serial.list()[0], 9600);
boolean mouseOverRect()
  return ((mouseX >= 50) && (mouseX <=150) &&(mouseY >= 50) && (mouseY <= 150));
void draw()
  background(#222222);
  if(mouseOverRect())
    fill(#BBBBB0);
    port.write('H');
    fill(#666660);
    port.write('L');
  rect(50,50,100,100);
If anyone has some insight on Serial Servo control, I would greatly appreciate it.
Cheers
  • Nick
hi
can you make the Arduino side code work by sending "H" or "L" through the serial monitor?
D
I gave that a shot. and it didn't work.... :-?
ah.. so that means there is something wrong on the Arduino side.
Next I would try: - checking the connections. If using a battery to power the servos, you need to connect the battery gnd to Arduino GND. - removing the serial checking loop entirely and having the code run the servo back and forth once a second. - using another output pin, as 13 has an integral resistor.
D
I've also just noticed there is something else occurring here....
If I power the board and servo through the USB, a tried and tested code using a potentiometer to move the servo runs perfectly, however that same code does not work correctly when the board is powered with a 9v power source.... There is a massive lag from turning the POT and when the values are actually received by arduino....
stumped on this one :-/
That sounds like the USB connection is making lots of servo current available, and that the servo may be underpowered by the 5V regulator. The on-board regulator has a little over 400ma available for external connections, and servos can draw a lot of current.
D
I think Daniel is correct. You can try powering the servos with a different 5V power source which should have no problem delivering 1A. I have powered servos from a 9V source directly that’s also powering the Arduino, that worked, but it’s probably not very good for the servos, since they are designed to run at 5V.
-Z-
Thanks for the replies.
Yes that seemed to be the case - I switched out the servo for another to test it out and it worked fine.
Going back to the Serial communication - I've got the servo working from keypresses (within the serial monitor) so the serial works fine within Arduino - I'm having a little difficulty on the Processing side - I tell it to send a character "k" for instance upon a specific event , but it does not exactly send that information to Arduino thus not moving the motor.
I'm very new at serial - do I need a carriage return in there to clean up the strings and allow arduino it read it clearly?
perhaps I should do some reading on serial communication - i've searched the site for tutorials, anyone have more?
I had similar problems here:-
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1185507207
Until I added an array for receiving bytes, and then running a sub once a certain number of bytes are received.
I used 'A' like a hand-shake, then two additional bytes are sent over determined by an array stored in a text file. Since 'A' is the starting point, the subsequent bytes are received in the order they are sent. Without that, I had a hard time getting them in the right order.
The code can be easily adapted to work on servo's. I was planning on doing that at some point in time since I have a need for running servo's from a hex script (.txt), so you can either wait, or try hacking the code yourself.
