Servo Control via Serial USB
Please forgive my novice coding skills here. I’m trying to create a servo control that takes in angles input from the Serial Monitor, and turns the servo to that given position. For some reason, whenever I try to type in a number with two digits, the code reads that as two separate numbers and turns the servo to each digit as an angle (from 0 to 9 degrees). I suspect this is a simple coding issue, but any help or advice would be appreciated. Code is appended below.
GEP
PS; Sorry for the double post.
#include <Servo.h>
Servo ServoA;
    ServoA.attach(9);
    Serial.print('Ready for angle prompt!');
    Serial.print("Please assign an angle for Servo A [0 to 180 degrees]");
    if (Serial.available() > 00)
          int AngValA = Serial.read();
          if (AngValA >= '0' && AngValA <= '180' )
           AngValA = AngValA - '0';
           ServoA.write(AngValA);
           Serial.print("Servo A set to: ");
           Serial.print(AngValA, DEC);
Some simple servo code you can try using the serial monitor.
// zoomkat 10-4-10 serial servo test
// type servo position 0 to 180 in serial monitor
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-21"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(1);
    if (Serial.available() >0) {
      char c = Serial.read();  //gets one byte from serial buffer
      readString += c; //makes the string readString
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n;
    char carray[6]; //converting string to number
    readString.toCharArray(carray, sizeof(carray));
    n = atoi(carray);
    myservo.writeMicroseconds(n); // for microseconds
    //myservo.write(n); //for degees 0-180
    readString="";
