Hi there everybody
i made a code to control my dagu rover 5 using a dagu 4 channel motor control, and a micro servo.
now i want to use to servo's, i use to commands for that: DW+the position and UP+position.
when i enter DW only the first servo reacts (as is should), but when i enter a UP command both the servo's go to that position.
and i don't know what i am doing wrong.
i hope somebody could help me out.
#include <Servo.h>
Servo pan;
Servo tilt;
#define PwmPinMotorA 10
#define PwmPinMotorB 11
#define DirectionPinMotorA 12
#define DirectionPinMotorB 13
#define SerialSpeed 9600
#define BufferLength 16
#define LineEnd '#'
int message = 0;
int redLED = 0;
char inputBuffer[BufferLength];
// motor pins must be outputs
pinMode(PwmPinMotorA, OUTPUT);
pinMode(PwmPinMotorB, OUTPUT);
pinMode(DirectionPinMotorA, OUTPUT);
pinMode(DirectionPinMotorB, OUTPUT);
pan.attach(2);
tilt.attach(3);
Serial.begin(SerialSpeed);
// process a command string
void HandleCommand(char* input, int length)
Serial.println(input);
if (length < 2) { // not a valid command
return;
int value = 0;
// calculate number following command
if (length > 2) {
value = atoi(&input[2]);
int* command = (int*)input;
// check commands
// note that the two bytes are swapped, ie 'RA' means command AR
switch(*command) {
case 'FA':
// motor A forwards
analogWrite(PwmPinMotorA, value);
digitalWrite(DirectionPinMotorA, HIGH);
case 'RA':
// motor A reverse
digitalWrite(DirectionPinMotorA, LOW);
case 'FB':
// motor B forwards
analogWrite(PwmPinMotorB, value);
digitalWrite(DirectionPinMotorB, LOW);
case 'RB':
// motor B reverse
digitalWrite(DirectionPinMotorB, HIGH);
// servo control
case 'PU':
pan.write(value);
case 'WD':
tilt.write(value);
default:
// get a command string form the serial port
int inputLength = 0;
do {
while (!Serial.available()); // wait for input
inputBuffer[inputLength] = Serial.read(); // read it in
} while (inputBuffer[inputLength] != LineEnd && ++inputLength < BufferLength);
inputBuffer[inputLength] = 0; // add null terminator
HandleCommand(inputBuffer, inputLength);
//----------- End Arduino code ---------------
