Hello Friends Hello, I am new to this and I've been seeing tutorials and codes but I find no one to help me ... I want to move a servo with a button but instead of tightening move it just an address, I when you press a button that does a cycle, I mean 45 ° to 180 ° and 180 ° to 45 ° infinitely and when I press the second is 45 ° to 90 ° and 90 ° to 45 °, not if I can help. A greeting.
Some servo button test code you might modify to your needs.
//zoomkat servo button test 7-30-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
Servo servo1;
pinMode(button1, INPUT);
servo1.attach(7);
digitalWrite(4, HIGH); //enable pullups to make pin high
press1 = digitalRead(button1);
if (press1 == LOW)
servo1.write(160);
else {
servo1.write(20);
//zoomkat servo button test 12-29-2011
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include <Servo.h>
int press1 = 0;
int button2 = 5; //button pin, connect to ground to move servo
int press2 = 0;
Servo servo1;
pinMode(button2, INPUT);
servo1.attach(7);
digitalWrite(5, HIGH); //enable pullups to make pin high
if (press1 == LOW)
servo1.write(170);
press2 = digitalRead(button2);
if (press2 == LOW)
servo1.write(10);
