Servo control with arduino
I am currently making a project where i can control 5 servo's with an arduino using a NRF24L01. The problem is that the NRF24L01 takes all the PWM ports so there are no ports left to control my servo. Anyone has an advice how i can bypass this without using an arduino mega?
thanks in regards.
The Servo library does not require PWM pins in order to work. Normal digital pins are OK
And the only PWM pin that an nRF24 actually needs is pin 11. Pin 10 can be used for other purposes as long as it is used as an OUTPUT. The control of the nRF24 provided by pins 9 and 10 can be provided by any pins.
Note also that the analog pins A0 to A5 can be used as digital pins
...R
Simple nRF24L01+ Tutorial
