Servo control
Dear all,
I am newbie with arduino.
We try to run a hacked servo, so far its working.
We have 3 positions, left, stop, right.
In fact the problem is that we do not start in stop position.
And that is what we want.
Here our code:
#include <Servo.h>
#include <IRremote.h>
unsigned long Value1 = 16591063; // where value is Left button
unsigned long Value2 = 16607383; // where value is Right button
unsigned long Value3 = 16623703; // where value is STOP button
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
Servo servo1;
int pos;         // variable to store the servo position
int Speed;       // Number of degrees to move each time a left/right button is pressed
// the setup routine runs once when you press reset:
  irrecv.enableIRIn(); // Start the receiver
// initialize the digital pin as an output.
servo1.attach(9); // attack servo to digital pin 9
pos = 90;         // start at midpoint 90 degrees
// the loop routine runs over and over again forever:
if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
if(results.value == Value1) {
servo1.write(93);
if(results.value == Value2) {
servo1.write(96);
if(results.value == Value3) {
servo1.write(95);
Regards,
David
You can do a Servo.write before you do the attach, if that's what you mean.
Please use code tags when posting code.
Hi AWOL,
We have done, problem solved.
#include <Servo.h>
int RECV_PIN = 11;
Servo servo1;
servo1.write(95); // start at stop position
servo1.write(93);
servo1.write(96);
servo1.write(95);
So easy, why i did not think about this.
Regards,
David
Or you can put the write after the attach.
Servo code that might help you test your continuous rotation servo.
// zoomkat 3-28-14 serial servo incremental test code
// using serial monitor type a character (s to increase or a
// to decrease) and enter to change servo position
// (two hands required, one for letter entry and one for enter key)
// use strings like 90x or 1500x for new servo position
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include<Servo.h>
String readString;
Servo myservo;
int pos=1500; //~neutral value for continuous rotation servo
//int pos=90;
  myservo.attach(7, 400, 2600); //servo control pin, and range if desired
  Serial.println("serial servo incremental test code");
  Serial.println("type a character (s to increase or a to decrease)");
  Serial.println("and enter to change servo position");
  Serial.println("use strings like 90x or 1500x for new servo position");
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    if(readString.indexOf('x') >0) {
      pos = readString.toInt();
    if(readString =="a"){
      (pos=pos-1); //use larger numbers for larger increments
      if(pos<0) (pos=0); //prevent negative number
    if (readString =="s"){
      (pos=pos+1);
    if(pos >= 400) //determine servo write method
      Serial.println(pos);
      myservo.writeMicroseconds(pos);
      myservo.write(pos);
  readString=""; //empty for next input
